Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
I have bosch 7052 oven trying to replace element in lower oven top screw of element hidden by fan how do I get to screw thanks
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
fitznog
SOURCE: Bosch fan oven not working
This does not mean your element is broken. Although it could be. Call Bosch and ask them if the unit has a pressure switch (you will need the model number). Pressure switches are more common on Gas ovens, but it might have one. If the pressure switch is not being activated by the fan, that could be the problem. It could be a contactor, it could be your power switch. It could be a break in the wiring. Or it could be your thermostat, or it could be the element. Service companies usually charge you for the cost of traveling to your place and around here hourly rates from $65-125 per hour for labor. It could take up to two hours to find out what the cause (or causes of the problem are) depending on how thorough they are. There could be a return trip charge as well if they need to order parts. And the cost of parts as well. you could be looking at anywhere from $300 to $1200 dollars depending on how many components might be damaged and the cost of the parts. If you want to save some money in the future, always check your fan blade to make sure it is free of debris (especially tin foil) and make sure the motor on the back of the oven has some clearance from the wall so it can cool itself.
Posted on Jun 17, 2008
Anonymous
SOURCE: bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Posted on Mar 31, 2009
Adrian
  • 109 Answers
SOURCE: i am looking for a manual for a bosch HNB 7052
Have you looked at this website?
http://www.boschappliances.com.au/content.asp?keyword=HBN7052&action=search&document_id=76
Posted on Jun 16, 2009
Anonymous
SOURCE: Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Is there a high failure rate on fan elements ?
It is not unknown for fan oven elements to fail quite regularly, some brands more than others, you must make sure you are fitting an element with the correct wattage, as this can make quite a difference to it's life expectancy.
Dec 01, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
I can hear the fan but there is no heat!
If the fan is working o/k, the n you need to fit a new o ven element, located at the rear of the oven compartment behind a removeable cover.
Oct 11, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
NEED TO FIT REPLACEMENT ELEMENT IN LOWER OVEN TOP SCREW BLOCKED BY FAN
To remove the fan unscrew the fixing nut clockwise as though you were tightening it, as it is a left hand thread, hold the fan blades at the same time to prevent the fan turning.
Ensure power is OFF.
Hope this helps.
Dec 11, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
A new element was fitted and now theres a vibration from the fan. how do you fix the vibration?
I'd suggest that either the fan and its associated washer are not located correctly and fully tightened or that part of the fan has been broken off, making it unbalanced.
Oct 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Bosch oven heater ring replacement
Hi, the fan is held in place with a left handed nut, once undone, then remove the steel drive washer by giving it a light tap, finally it is a case of shear brute force applied evenly. All you need is a 10ml spanner and a medium size cross head screwdriver plus a bit of muscle.
May 30, 2008 | Bosch HBN 7052 GB Stainless Steel Electric...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
42 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
