SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
SOURCE: goodman furnace went out. Light
Your main limit switch is activated. Maybe for good reason. This switch keeps the furnace from overheating. I have the same problem right now and I think my a/c coil may be blocked, limiting air flow through the heat exchanger and the furnace. Does your gas and main circulating fan come on for a few minutes before the switch activates and the light begins blinking?
Check your furnace filter and any return air ducts in your home - see if they are blocked or restricted.
SOURCE: my furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
SOURCE: My goodman furnace will start to ignite, then it
Another part that you might want to check is the flame sensor. It is a very good chance that this is the problem, the stat calls for heat, the induced draft motor (little motor on from of furnace), ignitor comes on, the main burner fires, just for a second or two, the burner shuts down, the main blower motor defaults to blower on!
If this is the issue;
Then this is what you do to fix it, kill power to the furnace, look where the burners are, to the left side there is a little wire, usually yellow or orange running to what kinda looks like a spark plug, one screw should be holding it to the burner bracket. take it out, at the end of the white porcelain is a small metal rod sticking out, it probably has a slight bend in it.
take some steel wool, or sand paper and clean the rod till is is nice and shiny, NOTE: when you take it out, it won't look really dirty, maybe just like a pencil lead,,,,it is dirty!
Just use the sandpaper and clean the rod till it looks like metal, "do not sand the white porcilen". Put the part back in and turn the power back on and run the furnace as usual.
90 % chance that this will fix your problem.
The rod get a build-up on it from the sulfur that is added to the gas, and has a hard time passing the milli-volt signal back to the furnace computer, which is passed from the ignitor, through the flame, to the sensor! This way the computer knows that all of the burners are firing and it is safe to run!
Please take time to come back and rate me, or contact me with any further questions!
Have a warm day :)
Sincerely,
Paul Gibson
NOTE!!
Do not touch the ignitor! The part that gets bright and hot! Even when it is cold, the oil on your fingers will cause it to burn out.
