SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
SOURCE: Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
SOURCE: I can't find the user's manual for this
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
SOURCE: I need help setiing the time on my adidas adh4004
You are right the manual is useless.
To set the watch it needs to be in T1 setting, you can do this by using the C (top right) button, to chose just push once and the number should change, hold to set it to T1.
After that, push the A button (top left), this should hopefully display 'Light'. If it still displays 'Offset' then you are still in T2 (offset lets you offset the GMT). Try the C steps again.
Once 'light' appears you can scroll through the menu using B (bottom left), at which point you should find the time selection option. It should be flasing, use the two far right up and down buttons to then set the time/date etc. Press B to move on to the next setting. When you are done press A.
SOURCE: Lost manual for watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
