Question about Boating
My Mercury outboard Model #402 has no spark. - Boating
Posted by Arlen Thayse on
william moore
    Novelist:
  • 184 Answers
Scariest ignition merc ever made. it controls the spark by running the high voltage through a pair of points. Needless to say these points almost immediately burn to a crisp, but merc says just run em- they'll be fine.
So- they are located under the flywheel which requires a special puller like a big motorcycle puller to get the flywheel off.
READ- take it to the dealer. at least you don't own a 400.
Posted on Nov 29, 2012
1 Related Answer
GetMeOttaHere
  • 2926 Answers
SOURCE: 2000 Mercury 75 outboard 3 cylinder with 3
No spark can be attributed to two components; The stator or the trigger assembly. Even if you had a diagram (available online @ Mercury), you will still need a test harness,a DVA adapter and a meter to measure the resistance of the CDM's (capacitor discharge module) ,stator and trigger assembly. Best case fix would be the trigger, most expensive would be the stator. If you remove the flywheel, and inspect the stator, you can inspect the the coils that are coated with a white epoxy, and if one or more are bad, they sometimes leak a black resin, indicating the coil(s) have been shorted and no longer provide voltage for spark.
Posted on Jan 22, 2011
I HAVE NO SPARK ON 40HP MERCURY OUTBOARD MOTOR
Hey Barbara,, get one of these manuals,,, you will need it to trouble shoot this outboard..
Mercury Outboard Manuals by Seloc 1965 2014
Aug 20, 2017 | Mercury Boating
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
What year is my mercury outboard searial no 3768233
Check here, you'll need the horsepower and lookup the serial-number range...
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
What year is my mercury 40 hp (402)please the number is 9034091
According to marineengine.com, it looks like it could be in the 1983 sequence of serial numbers.
http://www.marineengine.com/mfr/mercury_models.html
Aug 29, 2011 | Seloc Mercury Outboard Engine Repair...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Boating Logo
404 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
