Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Can an ice cube maker heater be replaced?
Unit makes ice but heater under tray doesn't warm up. If I run hair dryer under tray it will drop cubes and fill up again, freeze but won't release the cubes without a hair dryer.
Posted by terry Ingman on
Richard Roth
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 25, 2012
2 Related Answers
livewire874
Alf Hopkins
  • 618 Answers
SOURCE: Ice make will not release cubes. I put a hair
Or the heater in the ice-maker is bad.
Posted on Nov 17, 2010
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: my ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 17, 2012
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
HI, I have a KSRL25FRSS00 side by side. The icemaker fills with water and freezes, but doesn't dump the ice cubes. I've used a hair dryer on it to melt the ice a little and have got it to dump the...
There is a heater in the ice tray that is supposed to thaw the cubes a little bit so they don't stick to the edge of the tray. When the heater does not work the ice sticks and the motor wont dump them out. You can see more info and comments and how to here: http://www.appliancepartspros.com/repair-help/kitchenaid-refrigerator-ksrl25frss00-repair/ksrl25frss00-ice-maker-wont-dispense-ice.html
Jul 28, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker is not able to eject the ice cubes. You can see them partially exposed but they will not move. The unit keeps making noise...I assume it is trying to eject the cubes. How do I resolve this...
the under side of ice maker should be very warm. this is the heater that warms the ice mold . if its not hot ( warm) the the ice harvest is slow or not at all . if heater is bad or mold ruff or warn out . the ice mker wil have to be replaced . you can clean tray and use a food grade silcone and it will help if heater is ok .. mm .ps some times the ice cubes are too small and get jambed in the slots . if so adjust the cube side ( more water adjustment . this will correct the problem mm ..
Aug 17, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
OUR ADMIRAL ICE MAKER HASNT DROPPED ICE IN ABOUT 2-4 HRS. WE ALWAYS ADJUST THE ARM MANUALLY WHEN NEEDED AS THERE SOMETIMES IS SOME ICE CUBE BUILD UP. THAT DOSENT SEEM TO BE THE PROBLEM NOW. THE TRAY IS...
They sometimes get frosted up and don't want to work the motor properly...if you can get the face of it off, take a hair dryer and heat it up until the frost melts off...don't spin the fan motor if you have one on that unit. Then put it bad on and see if that will help if it doesn't you may have to replace the whole unit. They run around $190 if you do it yourself...not too hard of a job.
Oct 29, 2009 | Admiral AAV7000A
No water getting to ice maker ..no ice left in ice cube storage tray, I don't know how long it has been broken
Used a hair dryer last night to warm up the water pipe going into the ice cube tray...This morning we have ice!
Jun 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Jimmy
Dale Copeland
Dale Copeland
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
