My dryer keeps getting lint past the trap- cleaned everything and made sure it is seated properly-stiill sends lint outside. Now it is getting a brown burnt residue on hot air inlet which is transfering to clothes. I cleaned everything and it has reoccured, drying time has increased also. 2 years old!
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks Dan- I'm guessing your right-decreased air flow through dryer causing overheating. We are fed up with Affinity products and it is going out the door next monday"
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
SOURCE: Dryer will not dry clothes properly
Problem: The drum spins, but there is no heat.
Solution: This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
SOURCE: How do I clean the
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
SOURCE: My dryer model number LEQ2152ESO will get so hot
I would check the blower wheel. If it is loose or has any play replace it. Check the outside vent to see if air is blowing out the vent as strong as usual. If all that checks good the cycling thermostat is likely the problem. They are inexpensive and easy to replace. Here are a couple links that should help
http://appliancehelponline.com/dryerblowerassy.html
http://appliancehelponline.com/electricdryertroubleshoot.html
