Question about Samson EXPEDITION XP40i iPod DOCK PORTABLE PA SYSTEM DJ
Samson xp40i no sound
Power says its fully charged and no sound is coming from the speaker. It was playing one day and then the sound went out and hasn;t worked since? any suggestions?
Posted by apiccone968 on
1 Related Answer
yount9
Mark Yount
  • 7 Answers
SOURCE: how to fix a Samson XP40iw Speaker PA System
Have you checked the cables? If that doesn't fix it, you probably have a loose connection inside between the "mixer" unit and "amp" unit
Posted on Jul 25, 2012
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 | Music
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
What could b the problem when my speaker just went dead while playing
Do you hear any sound if you crank it up and go in front of it?
It sounds that the power amplifier has gone..
If you hear anything i believe that its not the final stage as it should have a relay to cut everything that goes to the speaker if a problem occures in the circuit..
Leave it to cool for an hour or so and try again.If it doesnt start up normally and you have warranty bring it back to the shop you got it for repair , else if you have any electronics experience ,open it up carefully (there are high voltages inside) and see for burnt components (resistor of 1/4 watt may have discolored or burnt at all)..If you have a multimeter, leave to speaker to cool unplugged from the mains for about an hour ,set the multimeter to diode check (where it beeps if you short circuit the terminals of the multimeter) and check all big transistors for short circuits...
Mar 12, 2012 | JBL EON 15 BAG G3
Hello, My robot will not tune. I pull out the knob, 8 red lights come on, strum the strings, nothing happens. It worked the first day, and on the second day, nothing. It's fully charged, tuning knobs are...
This is one that you'll have to take to a Gibson dealer- not a lot known outside of them, parts aren't readily available. You may need the hardware replaced
May 05, 2010 | Gibson Robot SG Special LTD Ebony
No sound from speaker, but works with external speaker plugged in
It sounds to me like you have blown the internal speaker.
Jun 17, 2009 | Music
No power is going to my amp
This sounds like there may be something loose inside of the amp. Please dont go pokeing around in side there your self. Unless you are a fix it kind of person. There could be electric charges , even if it has been unpluged for days. Have some ck. it out if you can not. I bet ya its not to serious , all so ck the fuse. Some times they will play around just befor they blow out for good . keep on playing DFD
Mar 29, 2009 | Line 6 Spider Iii 30
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Samson EXPEDITION XP40i iPod DOCK PORTABLE PA SYSTEM DJ Logo
323 people viewed this question
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
