Kids played with camera and now will not turn on
SOURCE: Can I get a copy
Hi - You can download the manual by clicking the link underlined in blue below:
C340 KODAK
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: lens won't go back in, camera won't turn on
i have the same problem with my olymus camera. its agravating because mine wont turn on and the lense is sticking out. my warrenty is up so im thinking about buying a new camera? im not sure because it cost more to repair.
SOURCE: My Kodak C340 wont charge. Help me
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
SOURCE: I need to replace lcd sdreen from kodak C340
I have some used lcd's(Kharkov,Ukraine) at working condition.Note:the display in this model factory have calibrated brightness & contrast settings.So if you replace display from other camera the brightness may be higher\lower than you used to.Manually adjust this settings is impossible.
SOURCE: installing kodak easy share c340 onto lap top
You can also try installing the software online by using this website www.kodak.com/go/easysharesw , once you're done make sure that the camera is turned on befor connecting to your computer.
