I have just received the camera which has been used and when I started it up, it said the memory card was full. However when I plugged it into the computer the card appeared empty. I've tried viewing the contents on the camera and it says 'unavailable'. Should I just replace the card or is there something I can do? Thank you
SOURCE: memory Card Error
Try checking the card slot in the camera. If it is dusty, then it might need cleaning.
Also, the problem could the the memory cards. If you are using a cheap brand, then they might not properly.
I recommend Lexar, Panasonic or SanDisk SD cards.
SOURCE: unable to view pics from memory card of lumix camera
hi i think your memory card is dead, just to make sure try it in something else. let me know Yvon chow !!!
SOURCE: I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Testimonial: "Thank you for quick reliable service!"
SOURCE: How do I switch between internal memory and memory card?
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
SOURCE: DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
