Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Microphone is not working!
Phone functions both making and receiving calls and speaker works but other party hears nothing. Microphone or setting problem?
I am having problems using Bluetooth with my Iphone 5C and can not make calls using handsfree. My phone seems to connect to the car easily, however, when I make or receive calls I can not hear the caller...
It could possibly be the speaker of the phone. there could be dusk in the microphone or when you listen to someone talking. this happened wit my phone.
My Acer X960 phone makes screeching sound when I receive a lot, hence I cannot hear the opposite party.
Sounds like your speaker has gone, when you next get a call put it on loudspeaker, it should solve the problem, as its a different speaker, you can put it in loudspeaker from options menu when you get a call.
1helpful
Xperia X8 - microphone not working while using skype
had this problem and resolved by downgrading my skype version.
skypev103b_e7yashh9.apk
Search web for the above from x8, download, get a file finder program from market and install the file from there.
With that said, although this has worked the few weeks I have owned this device, the last two days I am having trouble hearing the called party in the earpiece, but it works on speaker - anybody else have this behavior? At the same time, when receiving skype calls everything is fine.
2helpful
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
I can call but when somebody calls me I cannot here anything
In any phone cordless // Mobile or landline there are two things one is microphone & other is speaker. Microphone is when u speak caller party can hear u & speaker is to hear when someone from otherside speak. In ur case the speaker might be faulty get it repaire by the local technician
Dropped nokia e90; now others can't hear me
The microphone is located under the last set of keys . you can open it up and see if when u dropped it a connection came loose but my guess when u dropped it you damaged the mic itself therefore the only way to fix it would to be to get a new phone
1helpful
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
2answers
Lg viewty ku990
My earphones don't work. Nothing doesn't seem to be broken. Just doesn't work. Have to watch movies on speaker now. Really annoying.
Microphone has stopped working
Check the channel switch on the transmitter unit. Change to the opposite channel and retest. Check that the batteries are still good in transmitter AND receiver unit good luck
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
