SanDisk 2GB microSD Memory Card Logo
Question about SanDisk 2GB microSD Memory Card
I am using 2gb memory card in my phone. I used BitLocker function in Windows 7. Now my memory card doesn't open and can't be formatted. When I open the card, the message
Formatting memory is displayed. Then the message Formatting memory incomplete is shown. When the Memory card is connected, the status bar displays message status Not Encryptable for my 2gb memory card
3 Related Answers
Anonymous
  • 193 Answers
SOURCE: memory card not formating
first check to see that it is not write protected (flip the switch on the side). if you cannot read from it and it still will not format, then it has probably been exposed to a static charge and is dead.
Posted on Aug 17, 2009
Anonymous
  • 88 Answers
SOURCE: i'm using for sand disk
I've been encountering this issue. The problem may come from the card reader or the card holder. If possible, use a different card holder and of problem persists, try a different card reader or test on another computer.
Hope this helps!!
Posted on May 09, 2011
robert faass
  • 87 Answers
SOURCE: genx pe4ndrive.when I insert in lap top click to open it is displays not formatted.when I clic formatting button it is displayed that i will loose all memory of pen drive it's data.
Try it on an other computer... if that fails, it might have developed bad sectors (spots) reformat and do a scan, which writes and reads all memory locations... might be corrupted and/or broken, but try another computer first to make sure it is not a driver issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
Posted on Dec 13, 2011
Unable to format the 2GB
STEP 1 - Connect your flash drive, MP3 player (in MSC mode), memory card or card reader to the PC
STEP 2 - Open Disk Management
Windows 7 or Vista
Click Start, right-click on Computer and select Manage.
Windows XP
Click Start > My Computer > Manage.
Under Storage, click Disk Management on the left pane.
Windows 7 or Vista
Windows XP
STEP 3 - Format the device / MP3 player
1. Right-click on the drive / device you want to format then select Format.
2. Occasionally, a warning may come out concerning active partition, click Yes.
3. You can leave the formatting options such as the Volume label and File system to default.
4. Click OK to format.
Iam using bitlocker in win 7. in SanDisk 2GB microSD Memory Card . now data could not add and format the sd card.. pls help in format the s card.
You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
Hope this helps.
I using MMC card in my mobile. when it is opened, it doesn't work. it wants to be formated. but doesn't format. so please help me.
Format it on a PC and then use it on your phone...
Get EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
1helpful
I just bought 2gb SanDisk Memory Card, a few days ago it requires to be formetted and I dont know why. When I intend it to format at my PC it just says "Windows can't format E:/". What should...
try using linux
then also try using your phone or whatever the disk was to be used if not then g to control panel and look for the administrative tool click it, go to computer management and try format it from there. If all this can't work then, return the product to the dealer
My memory card doesn't store more than 2gb
Your file system is some FAT 32 (or some FAT modification). It has limitation. Limit is on 4 GB but sometimes can be less. You must convert it to NTFS system. You can use Exporer for that purpose (righ click on drive and Properties), or format it with NTFS option. But with NTFS lot of cheap devices will not work (they must pay to Microsoft lot of patents for compatibility). Windows or Linux has not problem with that kind of memory card.
Ok.... i have a kingston 2GB microSD card.... i can copy all the way to more or less 1GB on it, and it suddenly wais it's write protected. it makes no sense... i've used a usb card reader, and the...
You might be using a memory card with a larger capacity than your device can use. But as you haven't given any details regarding the make and model of device it's impossible to be certain.
One thing is certain though: FAT is a Windows formatting system. Just because they use it, it doesn't follow that other devices do; most cameras and phones use their own proprietary formatting system. To be safe, NEVER format memory cards in anything other than the device they're intended for, you can ruin them for use in anything other than a pc.
Jul 22, 2011 • Cameras
2helpful
Windows unable to format memory card
You can also try formatting your drive using disk management.To do so:-
  • Just right click on My computer.
  • Select Manage.
  • Select Disk Management
  • Find and select your Pendrive and format it.
Alternatively, you can open it from the command prompt
  • Open the command prompt and type diskmgmt.msc.
  • Press Enter
  • Select the pen drive, right click on it and click on Format.
If you using your microSD in phone,better you format the card using your phone
Thats it !!
I'm using for sand disk micro SD 2GB (NEW) card.the memory card open in my mobile phone(Nokia N73). smooth working.but the memory card not open in my computer. start-menu-my computer-removable...
Hope this helps!!
9helpful
2answers
I cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device....
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Top SanDisk Electronics - Others Experts
Marvin
Marvin
W.L.
Mike
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
