If you washer has an LE error code it usually means the washer has not reached the proper water level.
OE also has to do with the water level.
So what is wrong with it then?
Water level switch
Where is it located and how much is it?
Replaced water valve and level switch and now I get NF code and LE.....still problems,any other suggestions?
Take a look at this page.http://www.samsung.com/us/support/Suppor...
SOURCE: HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
