I need the security code cause im tryin to connect another device to it but it ask for the code
Hello download the user manual here:
http://homesupport.cisco.com/en-apac/support/routers/E1200
Select the version number.
It`s printed in on the product.
You need adobe reader to read the content.
Good luck
SOURCE: how do i remove devices from my linksys (model WRT
You shouldn't need to remove devices. I'm assuming you're referring to pc's and/or printers connected through a network cable? As long as each device is set to dynamically/automatically get an IP address, they will get a new one after the router resets. You can usually press the reset button on the router, assuming it has a little button inside a pinhole that you can press by using a sharp pencil or paper clip, though I'm not positive about this particular model. That will set it back to factory settings, which usually enables DHCP (dynamic addressing) on the router.
SOURCE: I'm having trouble getting my new laptop connected
If you can't remember the key you set up on the router originally then you will need to reset the key. Please confirm the model number of the router for me. You will need to connect to the router directly via ethernet. Then you can access using the appropriate IP address and change the security key. Once I have the model number I can give you the step by step information for doing that.
Thank you,
Lee
