SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can
download Whirlpool owner's manuals and installation
instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: whirlpool microwave model #MH1140XMQ-1. I needed
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
William E. Miller, AS-EET
[email protected]
SOURCE: Have a Whirlpool RMC275PD microwave. Light bulb
If you see no removable panel inside the cavity, it will be necessary to remove the housing to replace the bulb. Because of the nature of microwave energy, the fewer sharp edges and other irregularities in the cavity, the happier the magnetron is since all those have some effect on the distribution of the energy and efficiency of the unit. That's why one should avoid having any larger metallic container in a microwave. Using aluminum foil to prevent the drying out of certain types of foods is permissible because the ratio between moisture content of the food and the reflection of energy caused by the foil is not significant and the energy is mostly absorbed instead of reflected.
SOURCE: The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
