GE Spacemaker WSLP1100D Top Load Washer Logo
Question about GE Spacemaker WSLP1100D Top Load Washer
GE washer model SWLP1100D error FF
Machine starts to fill with water and after several inches it drains right out. Previously discovered the little black screw off thing on the back bottom and when I took it off a bunch of change and water came out. I screwed the thing back on and the washer worked fine for one load. Now back to the original problem of starting to fill and then draining over and over until it gives the error code FF. Anyone?
Posted by Tracy Shaughnessy on
Richard Roth
    Top Expert:
  • GE Master
  • 9,472 Answers
Loss connection in the door motor safety circuit
Recommended to replace control
Posted on Nov 24, 2012
5 Related Answers
Anonymous
SOURCE: washer does not drain water
Make sure the drain hose is not kinked
Posted on Jul 20, 2008
Anonymous
  • 5911 Answers
SOURCE: Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Posted on Dec 20, 2008
Anonymous
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Posted on Jan 06, 2009
Anonymous
SOURCE: My GE washer won't fill with water; will agitate
The hitachi machine bring an error message C1B1. Please assist
Posted on Aug 01, 2009
Anonymous
  • 1531 Answers
SOURCE: GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Posted on Feb 06, 2010
Water continuously drains and fills, and never gets particularly high
You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
1helpful
2answers
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
Solved: There was a piece of fabric caught in the water drain pump. Opened the cap at the back bottom right of the washer and pulled it out. Worked fine after that.
2answers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
When start washing, filling water comes out from
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an F20 error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
When starting the washer, it occasionally will not fill
Check the drain hose. The open end of the pipe the hose drains into must be higher than the top of the washer's tub (usually 30 inches or so off the floor, minimum) or the water can siphon right out. The drain hose should not be a sealed connection to the drain pipe. Try to extend the drain pipe up to about 36 inches off the floor level.
Frigidaire front load washer - e10 and water hose shaking
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Top GE Washing Machines Experts
Marvin
Marvin
Mike
David Shaub
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
