How do I shut off the hourly chime on my aqualite watch?
It has four function buttons and a blue light when the light buttons a pressed. It has a fifth button located on the front bottom of the face to activate the light in addition to the side button. Tried pressing the start/stop and lap/reset buttons together. Was told that would stop hourly chime. It did not.
Most digital watches set by holding down the mode or restart button until the display begins to flash. You can then cycle through the display and set on the right time.
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Question edited for clarity and toss in some CAPS.
Question moved from Reizen Phone to Resizen Watch.
Hourly Chime Announcement On and Off.
Hourly Announcement (Chime) ON/OFF
(When Chime is ON, the watch announces the HOUR every Hour)
Hold the 8 o'clock button while the watch is in the real time mode for more than 5 seconds until the watch says "Set alarm, Press 10 o'clock button to set."
Push 8 o'clock button 2 more times, until the watch says "Chime ON/OFF, Press 10 o'clock button to set."
Press the 10 o'clock button.
The watch says, "Press 2 o'clock button to turn ON, 4 o'clock button to turn OFF, 8 o'clock button to confirm.
To turn OFF a Chime Alert, Press 4 o'clock button. To turn ON a Chime Alert, Press 2 o'clock button.
Press 8 o'clock button to confirm.
After a Chime alert is turned ON, the watch will announce the HOUR every one hour.
To remove the hourly alarm (or 'chime'), try this :-
Press and hold the RESET button and then press MODE. If you want hourly chime ON - all the days will be displayed, press MODE button again to switch OFF the chime - all the DAYS will disappear.
It seems that most 4 button electronic watches have similar directions. There should be four buttons. Clockwise from top left is the Light button, followed by S2 (Stop), S1 (Reset) and finally on the lower left S3 (Mode). Who knows why they are numbered this way. To set hourly chime Hold down S1 and press S3. When all 7 day flags show the chime is on. When they are off the chime is off. To set the alarm hold down S1 and press S2. Alarm icon will display or go off. Release S1 button and display will return to normal time. Hope this works for your watch
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
To change the alarm settings on the Aqualite Men's Analog/Digital Watch, press the bottom left "Mode" button until you find the "AL" word next to your alarm time. Then let go of that button. Then press the top right (Start/Stop) button one, two, three, or four times to select your options (alarm on, alarm and chime on, chime on, alarm and chime off)
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst S2 - at 2 - St/Stp S3 - at 8 - Mode Light - at 10
Watch Control Normal Display: Hour, Minute, Second Push S1: Alarm time in Hours and Minutes Push S2: Month, Date S3: Change function
Alarm and Chime In Normal Time Hold S1 and the alarm time will be displayed. Press S2 once and Hourly chime will be on. Press S2 twice and Alarm will be on. Press S2 three times and Chime will be off. Press S2 four times and Alarm will be off. Press S1 and display will change to normal time immediately.
Setting Alarm Time In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons: 1) top right (we will call it S1 like this manual does) 2) bottom right (this will be S2) 3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day: Press S3 3 times, or until the following are flashing in the display : TU and seconds Set the minute: press S2 once and advance by pressing S1 Set the hour: press S2 and advance by pressing S1 Choose from AM (A), PM (P) or military time (H) Set the date: Press S2 and advance by pressing S1 Set the month: Press S2 and advance by pressing S1 Set the day Press S2 and advance by pressing S1 Press S3 to bring you to the time display
Setting the chronograph: The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display. 1. Press S3 (flashing in the display: SU, FR, SA) 2. Press S1 to begin. Press S1 to stop. 3. press S3 to return to the time display.
Setting the lap time: The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds. In the time display. 1. Press S3 (flashing in the display: SU, FR. SA) 2. Press S2 to clear setting 3. Press S1 to begin. Press S2 to stop. 4. Press S1 once and S2 twice to reset. 5. Press S3 to return to the time display.
Setting the alarm and snooze: The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display. 1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1 2. Press S2 once (minute will be flashing) 3. Press S3 to set alarm and return to time display 3. Press S1 to deactivate alarm 5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate. 6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm In the time display 1. press S1 and S2 simultaneously for alarm test.
Hourly chime Your chrono alarm sport watch ha the option of an hourly chime in the time display. 1 Press S2 and then press S3 to activate hourly chime 2. Repeat process to deactivate
think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
1) Press "Mode" button until Time is displayed. 2)
Press and hold "Lap/RST" button until seconds display starts flashing. 3)
Press "ST./STOP" button to change selected entry. 4) Press "Mode"
button to change from
seconds>minutes>hours>date>month>day of the week>time
format>date format 5) Press "Lap/RST" once you are done to set the
time.
To set Alarm time:
1) Press "Mode" button until ALM
is displayed.
2) Press and hold "Lap/RST" button until minutes display starts
flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from minutes>hours (remember to
cycle through for AM or PM 5) Press "Lap/RST" once you are done to
set the alarm.
To toggle alarm sounds on and off:
1) Press
"Mode" button until ALM is displayed 2) Press "ST./STOP" button to
toggle alarm sounds on or off (shown on display) 3) If alarm sound is
shown on display, alarm will go off every day at the selected time. To
turn off alarm once the alarm sounds, simply press "ST./STOP" button on the
watch.
