It won't work with the "Control Locked" light on
I mean I start wash with "Control On", but now it doesn't work, all the buttons are not working, just "Control Locked" light on. I tried to replug the power, still the same.
Posted by Stefeny Wu on
Richard Roth
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 24, 2012
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: control panel locked, won't unlock.
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You don't want kids bathing in the machine, no. Pl rate me nice.
Posted on May 14, 2009
Lloyd Carter
  • 153 Answers
SOURCE: The duet washer has been
try holding the sop/cancel button for 15seconds, this should reset it but may not completely remedy the problem. after you reset it see if any other lights blink or if any other problems arise
Posted on May 06, 2011
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: machine stops at spin cycle,
The symptons your giviong me poit to an issue with the pump probably not pumping all the water out like it should. Is this a top loader or front loader machine. In the mean time check and make sure the water is being pumped ourt completly before the spin starts.
Posted on May 11, 2011
marka19
marka19
  • 1430 Answers
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
James Foster
  • 251 Answers
SOURCE: Washer won't start. Power is on, pressed
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Posted on Jun 27, 2011
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
