Question about Apacer Memory Audio Steno AV220 MP3 Player
My audio steno av220 now only serve as flash drive
My Apacer audio steno av220 used to work as an mp3 player and usb flash disk memory. I've formatted it in my computer because one time, it acquired malicious files / virus. Now, it only works as my usb flash disk where I can save data files. It never plays mp3 files. What should I do? I think I have deleted some hidden files which serves as its code to interpret mp3 files and play it on. Where can I get such files? How do I make it function as an mp3 player again?
Posted by perongs on
1 Related Answer
bobhifi
Jacob Paul
  • 635 Answers
SOURCE: Hi, I have an old
Your balance 247MB files must be write protected. You will have to untick the protect tab and then delete. Or else you can connect the device to your computer and right click on the AV220 icon and click on the format command.It will warn you that you will loose all data -- just ignore it and click yes.
Posted on Mar 07, 2011
Testimonial: "Fast and very helpfull respons! Thanks!"
Hi, I have an old Apacer Audio Steno AV220 mp3-player. After deleting all visible files and folders, there are still only 11MB avaiable (out of 247MB). I guess I need to formate it(?) but how do I do that?...
Mar 07, 2011 | Apacer Memory Audio Steno AV220 MP3 Player
Micro sd cannot format
you can format the memory card on your computer first. then open my computer then right click then format. Then after it is done then you can format it on your player. hope this was helpful
Mar 27, 2010 | Apacer Memory AU822 MP3 Player
J ai le mp3 tout le temps allume et il ne   fonctionne pas
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ok tu peut essayer de la formater
Suivre les étapes suivant:
cliquer le : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
essayer de la formater en fat 32 et fat nfts
Merci
uttam
Jan 13, 2010 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Hello,I cannot access my 1GB apacer mp3 so plzzz help me to start that...
Plug it in and see if it shows up in my computer if not then install the drivers off the CD that came with it
Dec 02, 2009 | Apacer Memory APACER AUDIO STENO AV220 1GB...
To unprotect
It would depend on your Operating System. If you are using Windows 98 you'll need the drivers from your CD or from Apacer's website. The CD also has tools to perform various functions which might include protecting and unprotecting your flash disk.
Apacer's download site: http://usa.apacer.com/us/support/downloads.asp
Nov 17, 2008 | Electronics - Others
Usb drives show write protected when plugging in any device
ok, i found having the flashdrive in a usb hub doesn't help this (http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip ) repair kit to work cuz it can't recognize the flash drive.
so i took ejected it and put it straight into the computer usb and then tried again to format it and hooray. it formatted.
so i managed , thanks
adele
Nov 15, 2008 | iLO (2 GB) MP3 Player
How do I turn off the write protect on the verbatim 4gb flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 17, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Can't re-synchronize deleted files
your gonna have to reinstall all your stuff as I always tell peeps if you need to reformat or clean up your files and you got alot of data you should always have a copy or backup files on your puter. Sorry
Apr 11, 2006 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Apacer Memory Audio Steno AV220 MP3 Player Logo
63 people viewed this question
Top Apacer Memory Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
vinayghl
Tom Chichester
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
