Question about Stanley Garden
Staney pressure washer gun - Stanley Garden
1 Related Answer
dnewcombe1
Dana Newcombe
  • 1564 Answers
SOURCE: pressure washer water leaking from gun
Depending on the manufacturer, you may purchase a rebuild kit for these very inexpensively. It's just a small pack of o-rings and maybe a spring or two. It would be a good weekend job, pretty simple to figure out, I've got faith in you. Thanks Dana
Posted on Aug 22, 2009
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    How to fix 12POE-150 power washer leaking gun wand
    There are no parts available for the inside of the guns. All you can do is replace the gun.
    see parts in link.
    http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
    May 01, 2014 | FAIP 1500 PSI Electric Power Washer
    As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
    This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
    Thanks
    Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
    Engine runs , not getting any water flow when trigger pressed.
    Disconnect hoses.
    Look for kink in water hose.
    Check incoming water connection for filter washer
    Replace filter washer
    If you don't have a filter washer, put one in.
    Hook up water, and turn on
    Water should come out other side of pump.
    Turn on machine.
    Do you get pressured water out of pump.
    If no pressure, then pump is suspect
    Hook up washer hose without gun
    Does pressure come out of washer hose
    Finally, the gun trigger may be bad.
    We had to buy guns now and then.
    Search for pressure washer guns
    Following link shows guns we used:
    http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
    Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
    Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
    Hydraulic oil?
    Is this a pressure washer?
    Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
    Engine should have 10W30 motor oil.
    If you have a pressure washer ... and not water is coming out end of gun:
    Take all hoses off machine.
    Look at incoming water hose connection.
    The should be a filter washer.
    Clean or replace filter washer.
    Hook up water and turn on water.
    Turn on power washer and see if water coming out of pump is pressurized.
    Now hook up pressure hose without gun.
    Turn on pressure washer and see if water comes out of hose and is pressurized.
    Finally, the gun may be bad.
    We used to replace guns when they went bad.
    Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
    My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
    Good news, your engine runs
    But your pump may be bad
    Here's how to test your pump
    Check oil as outlined lower down
    Disconnect the washer hose and gun
    Connect water hose and turn on water and water should pass straight through the pump
    Look for clogs in the hose-end where water hose connects to machine
    Turn on machine and see if water shoots out pump
    If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
    Look for clogs in the end of each water connection.
    Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
    Finally, the gun trigger mechanism may be bad
    I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
    Check your pump oil
    Pump oil is SAE20 or SAE30 non-detergent motor oil
    Pump should be no more than 1/2 full of oil
    Use plastic hose to drain pump oil
    Do not turn machine on its side or turn machine over or engine oil will run into carburetor
    Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
    Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
    hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
    Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
    I plug the gun in the electric socket but it is not working
    yes you need to charge if its battery powered they dont come ready for use....but if its still dont work bring it back to home depot ....
    May 15, 2009 | Tools & Hardware - Others
    Garden Logo
    24 people viewed this question
    Top Stanley Garden Experts
    Dennis Key
    Dennis Key
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    mpservices
    Are you a Stanley Garden Expert? Answer questions, earn points and help others
