Hi,Im trying to connect my ibm a21m thinkpad to the internet ,but cant.Id like to connect wireless,if i cant Im using cable ,any help on getting me started up.
You need the next three letters or numbers after 2628 - ___ Go here http://support.lenovo.com/en_US/downloads/default.page?selector=expand click on laptop and tablets click on thinkpad A series then A21m Then 2628 then the next three then your operating system then voila there you have all your drives and any update for your thinkpad Bookmark so you will always be able to fix what ever may be wrong.. Please rate!!!
hi part of the information was fine,but when i get to 2628 i dont no where to go from there
look on the bottom of your thinkpad it should say type 2628-(something)you need the rest of the numbers to get the drivers for your computer
thanks again for all your help,but im still getting nowhere,all it says is 6v3.36a
Download thishttp://www.filehippo.com/search?q=cpuid and run after you run it click on mainboard you will see the model number 2628___..Here is a pix of my thinkpad's bottom you will see it say's 2373-7FU..You need those last three
thanks very much this is a great help,there just another few questions i need to ask you ,what drivers do i need to download,and the who problem i had was i had no internet,on the thinkpad so how can i download without this,thanks again
SOURCE: IBM thinkpad 2647 T21 LAN Card Driver files needed...
if you are using the internal LAN card to connect to the cable modem, no additional drivers will be needed. However, you would need to configure TCP/IP settings to use a DHCP server to automatically configure the IP address. you would also need to check whether or not you have the right CAT-5 cable. you might need to buy a crossover cable.
hope this helps
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
Note:
If the card has a exclamation mark over a yellow background, then this
is an indication that the card is experiencing a problem. Go to Driver
download step 5.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
If you double-click the previously mentioned system tray icon, the
configuration utility of the wireless card will appear. This utility
will be able to show the status of the wireless card, showing what
channel the card is using and what signal strength is being received.
It may be difficult to maintain a connection if signal strength is low
due to either interference or distance. For example, interference can
be caused by 2.4GHz cordless phones, other Access Points in the area,
and physical structures such as load bearing walls or metal partitions.
Note:
The utility can be used to configure the wireless card settings, but if
using Windows XP Zero Configuration or Access Connections, you will
need to use those programs to actually configure the wireless card as
they will overwrite the setting of the utility.
