Question about Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black
To unlock home screen lock - Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black
Posted by elizabethfaw on
sardon67
    New Friend:
I forgot my google account to open my galaxy tab lock
Posted on Feb 09, 2013
easyhits01
    New Friend:
    Problem Solver:
  • 15 Answers
After 5 tries it will ask you to try later.. but at the bottom you will see forgot pattern... click it and login to google account that you have in you android now draw new pattern
Posted on Nov 23, 2012
How to unlock home screen on lg android
Unlock home screen
Kelli, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to turn off the screen lock on my LG G2
How to bypass Android lock screen pattern PIN or password
Solved Forgotten the Password of the Lock Screen
Hard reset your Android phone or tablet when you forget the passcode or...
Jun 07, 2016 | LG Cell Phones
I have a new galaxy S5 and i set it up with fingerprint to unlock but it keeps going reverting to password to unlock, how do i get it to stay on fingerprint?
Here is another way to unlock pattern lock for Samsung Galaxy phones, also works with password, fingerprint and PIN. Moreover, no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Oct 06, 2014 | Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" data-src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" data-src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" data-src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" data-src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
Keypad lock
At the home screen, you activate the keyguard when you press and hold the Back key. From the home screen, select Unlock and press the Back key to unlock the keypad.
Jun 08, 2013 | Kyocera Loft / Torino S2300
How to unlock it
How to Unlock an Apple iTouch
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions
1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen.
2 Slide your finger on the iPod Touch's unlock bar.
3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Jan 07, 2012 | Apple iPod touch
Screen black and wont unlock thanks to Lock 2.0 I was using the phone trying to send a Facebook message and got impatient. Then the screen went black. Im using Lock 2.0, but the original lock on my Droid...
It can be fixed if you keep pressing the home button repeatedly. It will finally give you theoption to set your home default back to LauncherPro. If you wish to uninstall the Lock2.0 Hit Go to Menu Say Settings Once in Settings you can navigateto Applications and uninstall the Lock 2.0. Good Luck
Jul 13, 2011 | Android Apps
I erased all content and settings on my jailbroken iphone 3g and now its stuck on the start up screen
Plug the iphone into your computer and restore the phone using itunes. If the computer won't recognize the phone put it in DFU mode by doing the following.
1. Hold the lock/unlock button for 10 seconds. 2. Continue holding the lock/unlock button and also hold the home button for 10 seconds. 3. Release the lock/unlock button and continue holding the home button for 10 seconds.
After the connect to itunes screen appears on the phone, plug it in and attempt to restore again.
Mar 08, 2011 | AT&T Lands Phones
My thermostat is not working. It might be locked. It's blinking with all of the information it holds flashing on the screen. The part number is: tstatccnhp01-c My heat is no longer working. Can you...
Instructions
  1. 1 Unlock a partially locked screen by pressing any locked key, which will bring up the "Screen Locked" message. Next press an unlocked key, which will likely be the temperature up and down arrow keys. This will unlock the screen.
  2. 2 Press the "System" key from the home screen. Five blank touch keys, flanked by the "Done" and "Cancel" keys, will appear. Hold down the middle key for about five seconds. The Advanced Settings menu should come up.
  3. 3 Change the User Setup Number, found in the bottom left of the screen, by pressing the middle arrow keys up or down. Set the number to "0670," the universal unlock code.
  4. 4 Turn to the arrow keys on the right side of the screen. Press the keys up or down to change your options. Selecting the number "0" will unlock the screen, while choosing "1" will partially lock it. You can fully lock your screen again by selecting.
Read more: How to Unlock the Screen on a Honeywell Thermostat ' eHow.com http://www.ehow.com/how_7667347_unlock-screen-honeywell-thermostat.html#ixzz19ktDWSq8
Jan 01, 2011 | Heating & Cooling
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
My oricom wireless home phone is locked
press down on the # key for a couple of seconds as this also unlocks the phone.(the key symbol isn't very clear but it is there.
plus you can find user manuals for most phones online.
Oct 11, 2007 | Lands Phones
Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black Logo
473 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
