Intel D102GGC2 Motherboard Logo
Sivaraman Posted on Nov 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Intel Compatibility Support says that D102GGC2 supports a max. of 2GB DDR2 PC-400 or PC-533. But I cant find PC-400 or PC-533 in the market near my hometown. Only PC-667 and PC-800 are available. Shopkeepers say tat both will be compatible. Wat to do nw? If PC-667 is compatible, then whether to install a single 2GB RAM or 2 * 1GB RAM for each slot?
Hans Pedersen
Level 3:
  • Intel Master 3,606 Answers
  • Posted on Nov 23, 2012
Hans Pedersen
Intel Master
Level 3:
Answers
3606
Questions
0
Helped
2231779
Points
8683
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Feb 22, 2009
SOURCE: Compatibility of RAM
No hell no!!!!!!!!!!!!
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
I have a d102ggc2 mother board and i was using ddr2 533-1GB RAM, now i have bought a new ddr2 667 to upgrade it to 2GB memory. The system is able to detect only one RAM even if i plug in both together.
I have checked the INTEL site and read the specs on this MB. It only lists support for DDR2 400 and 533 RAM. I can only assume that either some upgrade to the board has been made, or that your 667 RAM will only be performing at 533 speed. The specifications manual lists very specific guidance as to what RAM DIMM design(s) are acceptable. Many double-sided options are unacceptable. It is possible that the system may not be seeing half of each DIMM because of the restrictions on approved RAM modules. This is an older board, and many of them where very fussy about whether you could use single and double sided RAM. Later boards overcame that issue.
Will 2gb ddr2 800mhz ram support d102ggc2
No. The maximum system memory that can be installed in 2GB, that being two 1GB RAM modules, Also the board only support DDR2 400 or DDR2 533 RAM.
4helpful
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
2answers
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
1helpful
2answers
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Im plannin 2 upgrade my RAM..My mother board(Essential series D102Ggc2) supports DDR2 800...my processor is Pentium D 820+ ...my query is: DDR2 800 is supported by Mother board but is it supported by my...
Your motherboard has the follwing memory support : DDR2 533/400 SDRAM 2 slots, Single-channel (2GB2 Max). As long as it is supported by your motherboard there would be no problem since your processor is also supported by the motherboard.
Please refer to the follwoing links from Intel:
1. http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/cs-026580.htm
2. http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
3.http://cip-origin.intel.com/cd/channel/reseller/apac/eng/products/desktop/bdb/d102ggc2/feature/index.htm
1helpful
3answers
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
2answers
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
