SOURCE: The Sony PRS-600 Reader has a well-known screen
The PRS600 Reader doesn't have any settings to increase the brightness and contrast. Howevver, this is not a well-known issue with the PRS600 Reader. You may try resetting the Reader by pressing the RESET button. If the issue still persists, unfortunately the Reader may require service. Please follow the link to get it repaired: http://eservice.sony.com
SOURCE: sony PRS-600 permanently 'Restarting' so I can't
Please check whether the Reader is fully charged. Connect the Reader to the Computer and keep it connected at least 4 hours to get it fully charged. If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object. That should resolve the issue.
SOURCE: I purchased my Sony prs 600 a few hours ago
The error -474 or -1106 sometimes occurs after an issue with validation or authorization in the Reader (eBook) Library software.
From the Reader (eBook) Store, deauthorize the computer.
Close the Reader (eBook) Library software.
Reopen the Reader (eBook) Library software.
Sign in to the account to authorize the computer again.
Try again to download a book purchased previously from the Reader Store.
If the error still occurs, proceed with the steps below:
Install the Adobe Digital Editions software. Use the installer at http://www.adobe.com/products/digitaleditions.
Setup Assistant will be displayed in the Adobe Digital Editions program.
Click the Authorize button and then the Finished button.
Deauthorize the computer using Adobe Digital Editions
NOTE: Press Ctrl-Shift-D to deauthorize the computer.
Reopen the Reader Library.
Go to the Reader Store and sign in.
You will now be able to download an eBook and transfer it to the Reader device.
Resource 2
If issue persists, deauthorize the computer, then follow the steps below.
Browse to http://www.adobe.com/products/digitaleditions/ and download the software.
please sign in with the Adobe ID and password when prompted .
Now, click on the "Activate" option and close the Adobe Digital Editions Software
Reopen the Reader Library software.
Sign in to the Reader Store.
Please perform the above steps and that should resolve the issue.
SOURCE: My reader PRS-600 is stuck on a page
press the reset button on the bottom. it might take a couple minutes to reset, but it always helps mine.
SOURCE: Hi, How do I replace battery on Sony reader
That's tricky. In order to change the battery you have to open up the Reader. I wouldn't recommend that... and I'm surprised you would need to change the battery at all at this point. If you absolutely have to, contact Sony or take it to the place you bought it and ask if they change the battery on these devices.
