SOURCE: copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
SOURCE: Panasonic Lumix DCM FS5 camera. Inbuilt Memory
delete the pictures (you should be able to upload them first)
SOURCE: I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Testimonial: "Thank you for quick reliable service!"
SOURCE: Replacement cable for Panasonic Lumix DMC-FZ5
Forget the cable. Do what the pros do...use a card reader.
