Computers & Internet Logo
Question about Macally Computers & Internet
Hi friend iam unable to format my 8 gb iball cordial pendrive it shows the disk is write protected and nothing is copied
It shows write protected nothing gets copied and unable to format it
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: formattin of pendrive
Your pen drive probably lost or never had a partition table. Unallocated space means the space isn't allocated to either a partition or logical drive.
Rightclick the drive in Disk Management, there should be an option to create a partition. Right after you create it. It wil ask you to format it.
Let me know whether it helped.
Please rate my solution when this was the answer to your solution.
Greetings,
DarkNeogen.
Posted on Jan 24, 2008
Anonymous
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
Anonymous
  • 32 Answers
SOURCE: windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Posted on Mar 12, 2009
Anonymous
  • 1142 Answers
SOURCE: 40 GB Kingston Pendrive Showing 8 MB & unable to format it.
Format it using a format utility which you can download it from any free software sites, type in format utility.
Posted on May 04, 2009
Anonymous
SOURCE: Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Posted on May 16, 2009
My 8GB kingston pendrive is showing write protected and couldn't format or copy files on to it...
i have my 8 GB Kingston pendrive i have formated it. But afterwords when i am going to copy some data ie photos and film it shows write protected, so how can remove this write protected from the same.
How to remove write protected in my 8 gb transcend
hi........please check that if there is switch in your pendrive..if present turn it other side..if not than follow this steps... 1. download a software from here http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
2.now fromat your pendrive by this software and than scan it for virus ...
hope this will solve your problem
Hi friend i have a problem after coping the 1gb in my Iball Pendrive it showing write protection please help meeee
U have to check whether pendrive is in NTFS or FAT format. Change it into NTFS format by doing a quick format by enabling this check box. Right click/properties on the pendrive
4helpful
2answers
Windows was unable to complete the format
sir
have a nice day
Sir, iam mustafa i have problem with my pendrive i.e transcend if iam copying or deleting any doucments it is showing that the disk is write protected. iam facing this problem from past five days.i have...
Have you checked the write protection notch on drive? Some systems also have usb write check feature. Try to disable it. If all fails try to format using HPflash. Download it from web and give it a try.
2answers
Displaying write protected while loading and deleting files
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Write protected pendrive
I protect my pen drive by this software
http://penprotectorenglish.wordpress.com
I hope you can leave protection from your pen drive
Regards
21helpful
7answers
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Open Questions:
Top Macally Computers & Internet Experts
Paul Bade
Mike
ADMIN Andrew
ADMIN Andrew
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
