Trying to install a printer
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Push Button Configuration (PBC)
NOTE: The PBC method is to be used if the wireless client device (device that you are using to connect to the network) has a WPS button (either an actual one or a virtual one).
Step 1:
Click or press the WPS button on the client device.
Step 2:
Click the WPS button on the Linksys device. A pop-up window from the Wireless > Basic Wireless Security tab of the Linksys device will appear. This window will indicate the progress of WPS client configuration.
