The bobbin thread does not catch the top thread
Try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly
also make sure the bobbin is turned the right way
it's also possible that the machines timing needs to be checked
here is a link for a free manual
http://www.singerco.com/uploads/download/694_5505-5525.pdf
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong. I have this machine, and I know that it is really easy to put the bobbin case in wrong. Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth. My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works. Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right. In other words, it has always been my fault.
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
SOURCE: singer 5525 sewing machine knots
You can go here, search 5525, and download or purchase an instruction manual for
your machine, if you have misplaced the one that came with it. It looks
like there are some available as downloadable pdfs for free and some physical ones for $15. https://www.singerco.com/accessories/manuals.html
Also, Singer has just installed new Q&A features on their website.
You can
go here: http://new.singerco.com/products and look for your
particular model or machine category. At the bottom of the product page, you can post
Questions for singer experts and other community members to answer!
Good
luck!
