Question about Pioneer Car Audio & Video
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
I have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp my problem is that every time i start the car the subs bang once real hard other than that it works as it should i have it all wired the correct way to the best of my knowledge only thing not connected right is the power remote wire from amp to a power source.. i just took a small piece of wire an hooked it straight to the power cord from amp/// is this OK if not plz tell me where to connect it i drive a 01 Buick century
Posted by eric red on
Lissa Wied
    Sergeant:
  • 344 Answers
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Posted on Nov 28, 2012
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: my subs sound distorted and dont pound right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Posted on Mar 09, 2009
Anonymous
  • 77 Answers
SOURCE: alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Posted on Feb 18, 2009
ampman
Mike Ryan
  • 98 Answers
SOURCE: i hooked up the pioneer
either the rcas arent outputting the audio signal or you have a bad se tof rcas. An amp is obiously not your issue in this case.
Posted on May 09, 2008
Anonymous
  • 6966 Answers
SOURCE: sub wont hit
Appreciate again the "Ask Me".
Appreciate the "FixYa" rating you have given me here. moz-screenshot.jpgA request if I may, my being able to assist you is largely dependent on my standing (rating and raking) on the site. Since the Panasonic has been successfully dealt with, perhaps you can re-evaluate and rate the following as you see them fit:
Many thanks in advance. As to your current concern, the 400watt bridged amp:
  • if the Panasonic was wired reversely, might it be possible that the sub amp was likewise wired reversely and therefore suffered similar electronic failure?
  • most high power amps have a built-in DC to DC power supply other than the external 12VDC, these would often fail if reverse power is delivered even just once;
  • since it is heating, then it is actively drawing power. that would mean that (if it is wired correctly), the SMPS (switch mode DC to DC power supply) might have a problem. Often culprits may include:
  1. capacitor;
  2. regulator;
  3. diode;
  4. or any of the other components.
Further diagnosis leading to a repair would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron. Or perhaps you may again seek the assistance of whoever worked on the Panasonic.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
Anonymous
SOURCE: No sound..amp has power to it
After three days of torture, I was going to rip it out, until I decided to make a fresh ground. I drilled a small pilot hole and got a brand new self tapping screw...voila!!! Works like a charm.
Posted on Sep 19, 2009
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
My kenwood radio model number kdc mp 528 plays but dont nothin show on the display screen whats the problem
there are probably bad solder connections on some surface mount resistors inside of the deck.
Aug 25, 2010 | Kenwood KDC-MP528 CD Player
Kenwood kdc mp228 now working with amp/subs
Hi, ensure amp has 12v on the "+" and "rem" terminals and has a good ground to the amp, This is all the amps needs to start up
May 05, 2010 | Kenwood KDC-MP228 CD Player
Deck shuts off, when loud, while idling or at stop lights.
You are working your deck to hard, it is overheating and shutting down (protection mode) You like it loud, you will need a 4 channel amp. Also check the ground on your deck to ensure it has a nice connection.
Jun 02, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Programing My Deck
Follow the below link for your manual: http://inform2.kenwoodusa.com/manuals/KDC1028.pdf Your welcome! Should you require any other assistance with this let me know Good Luck L8R
Sep 18, 2007 | Kenwood KDC-1028 CD Player
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
