Question about Pelican Camping, Backpacking & Hiking
Pelican mitylite 1900C
I have a Pelican MityLite Submersible 1900C flashlight. It was secondhand and abused with corroding batteries left inside. I believe I have resolved the corrosion in the main body, but the bulb/switch assembly is a mess. I got the bulb out to fix the corroded leads and can't get it all back together. Has any one had success reassembling this. Is there a diagram or manual available that shows how it goes back together?
Posted by Scott Klingler on
5 Related Answers
Anonymous
  • 70 Answers
SOURCE: battery corroded. Not sure, but when I look with
maybe you can get the answer at http://www.discount-laptop-batteries.co.uk.
Posted on Dec 17, 2009
gotgeek2
Bob
  • 565 Answers
SOURCE: 1 "D" cell battery is corroded and stuck inside.
Here are the instructions:
http://www.maglite.com/pdf/CustServ/CD_switch_repair_8_0410212004718132.pdf
If you remove the tail cap (the part that you unscrew to put the batteries in the flashlight) and the head assembly (the part that has the light bulb) you should be able to push the battery out. Wear some of those disposable latex gloves as that chemical that comes out of the batteries is very corrosive. Or at least wash your hands really well before touching anything, especially your eyes. Good luck.
Posted on Nov 16, 2010
Anonymous
SOURCE: My 1994 Pontiac Grand Prix's
Anything can be fixed
You will have to fabricate the worn
and rusted brackets,etc and do some
welding.
I guess you could section part of a good
subframe at the salvage yard and weld in
That would be time consuming
You have what I will call a hobby or restoration
project. Only a few of us have machine,fabricating
and welding skills to do that type of work
I really would feel uncomfortable paying some to
do it.
Posted on Apr 27, 2011
teds_repairs
teds repairs
  • 2101 Answers
SOURCE: corroded terminal assembly 1999 rav
all part stores have the battery terminals ,and they are easy to replace
Posted on Dec 13, 2012
Mani Manitas
SOURCE: corroded batteries stuck in a mini AA maglite
Yesterday I need to solve this problem with my MagLite Solitaire. My solution was open a little hole in the negative pole of the corroed battery with a Dremel and before screw down a drywall bolt into. At last I pull with a pliers.
Posted on Jan 24, 2013
Streamlight Model 4, AA, Propolymer Torch: It's an older model never been used, have put in new batteries & it will not work at all. Any solutions?
If batteries were left in the flashlight, it could be corroded on the most inner contact, shine a light, if it's green, try cleaning with alcohol and some scotchbrite, roll it up to fit inside the barrel.
Jun 16, 2015 | Camping, Backpacking & Hiking
HOW TO REMOVE CORRODED AAA BATTERY FROM MINI MAGLITE?
Try some baking soda with a few drops of water, it should loosen it up.
Oct 08, 2014 | Mag Instrument AAA Mini Maglite...
Corroded battery in high beam 1watt
battery sat inside to long or was overcharged... not worth saving
Dec 29, 2013 | Rayovac Highbeam Flashlight 1 Watt Luxeon...
Pelican 7060 flashlight manual
FlashMax G179 - Waterproof CREE LED Flashlight
Adding the particular FlashMax G179 water-proof, powerful DIRECTED Flashlight. This kind of torchlight will be one thing to seriously acquire anxious about. It really is really potent. Remarkably resilient. Water-proof. And also makes use of Cree LED's, and that means you realize you'll get white colored mild together with decades regarding program using this attentively developed Flashmax DIRECTED Flashlight.
Apr 17, 2012 | Pelican 7060 LED
Stealth lite 2400 user manual
there are 2 signs mark ( "+" & "-" ) on batteries flap's innerside,
check it and check the signs on batteries as well.
now insert the batteries accordingly.
Dec 12, 2011 | Pelikan Pelican StealthLite 2400...
How do i change the bulb?
Unlike conventional incandescent flashlights, where the bulb unscrews or pops out of the reflector assembly for replacement, the Pelican Sabrelite bulb is permanently mounted in the larger assembly. The entire "lamp module" is replaced as a single unit.
Replacement lamp modules can be found on the Internet and at some outdoors stores. For example, Amazon.com sells these, both individually and in 2-packs. Prices vary depending on the website, but just now, I saw them in several places for under $9/each.
Jun 06, 2011 | VWR Super SabreLite Submersible Flashlight...
Nov 16, 2010 | MagLite Mag-Lite& Flashlight
Pelican 4300
Send it back to Pelican. They have a lifetime warranty and are one of the few companies that actually stand behind their products.
Nov 30, 2008 | Pelikan Pelican 4300 Nemo Flashlight
Camping, Backpacking & Hiking Logo
1,988 people viewed this question
Top Pelican Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Pelican Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
