I suggest you to check the Vents. I had a similar issue where my 12v compressor car fridge freezer stopped working and I found that I had put the Fridge Cover the other way round which accidentally covered the vents
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
SOURCE: camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
