Question about Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive
External drive not picked up on computer - Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive
  • Samsung Master
  • 27,725 Answers
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Posted on Nov 22, 2012
Anonymous
SOURCE:
Not Being Reckonised
Do other usb devices get picked up? What operating system are you running?
Nov 13, 2013 | Hitachi Computers & Internet
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My external has stopped working- it also has an odd sensation when I pick it up rather like two identical magnet ends being held together. I only bough it 4 months ago and want to get the data from it!
is the issue a power 1 or does it power up but your computer doesn,t regonized the harddrive within the external...have you tried a separate power supply/usb cable....or try a different usb port in another computer
regards Tony
Mar 31, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External to internal with sata plug
It will be a setting in the BIOS to enable SATA hard drives after you select it will give it a drive letter and show on computer. Cheers from Scott and please dont forget to vote
Jul 17, 2010 | Western Digital My Book Essential 1TB...
I have a toshiba ez external hard drive and I hate it... just want to clear it and send it back. but can't figure out how to do that
Just open it and highlight everything then rt click and pick delete,
and you should go to my computer, and rt click on the drive letter
and pick format, and format the drive.
If you have personal info on it, get a program called boot and nuke,
its free for the once write, you boot from the disk you make
and it will erase so that most people can not retrieve data from it..
Feb 05, 2010 | Toshiba 120GB USB 2.0 Portable External...
I have a Toshiba 250GB External Hard Drive w/ USB cable and it came with no instructions. I have used it once and went to use it, plugged it in and got the little sound on the computer and.....Nothing. How...
this might be a tab bit late....but most external hard drives do not come with too much info if any at all...go to start/my computer/you see the the external drive...right click on it (to get it ready for use) select properties..format it...yes/okay...now its ready for you to download any file you wish...you see the letter on it (the "c" drive is your primary drive)...this drive is your secondary drive....so when you are typing in word/excel and you want to save...you will save as (pick the drive letter)...same as music /video you will save as (pick the drive)...now right now you can click on the external hard drive it just open (blank page)..right click any where on the page..now pick new folder type "music" (this folder is where you can store music...now right click again on the page click new folder again rename it "photos' and can create folders for any thing you wish..when you save you just pick this drive/folder...feel free to rate the help
Dec 10, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Computer doesn't detect
This is the best solution, unplug the device carefully, pick it up slowly, go to your room and stick it up your ***.....
May 30, 2008 | SimpleTech Pininfarina 80GB External USB...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive Logo
191 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
