Sounds like a wheel out of balance,tire low on air, tire belt shifted (starting to go), loose wheel, bad wheel bearing. press the helpful button and check links below Diagnosing And Repairing Wheel Vibration
You need to check your front wheel bearing you will get a wobble from a collapsed wheel bearing,I've had it happen to me on my fireblade and since then I replace my bearings every spring when I'm about to get back on the road after winter,just see if your front wheel moves side to side even if there is slight play. Hope this helps. Adrian.
Front wheel to rear wheel alignment needs to be checked. Both in same vertical plane and both on same centerline. (you can use an 8'flouresent bulb for this. Takes two people. Also check spokes in the back wheel. Hope this helps.
Hi, Anonymous and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swingarm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day. https://www.youtube.com/watch?v=3UGrqIit0zc http://www.mediafire.com/file/u6rd3qqr73d2qug/2011_Harley_Dyna_Service_Manual.pdf https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hhttps://ownersmanuals2.com/harley-davidson/wide-glide-2011-owners-manual-66669dmc https://www.6ya.com/ to speak to me personally
