Its says that it cant load drive q
Hi
Do you mean your system restore, sometimes the hard drive will not be able to restore your laptop to a earlier time because of file corruption.
You can try and google the problem to see if anyone else resolved this issue or you will have to save your data and re-install windows and the drivers again.
cheers
SOURCE: Cant perform a quick restore.
what size is yous hard drive and is the windows installing it'self properly and the other problem is have you got all the motherboard drivers if not then the system will become unstable and the hard drive will need to be format back to manufactures default as the files thet were on drive are burrired deep and the only way to get rid of problems is using a program called kill disk then using your win 98 start-up floppy and fdisk the hard drive then partition then format the hard drive then install windows on then all other files for motherboard and graphics and other devices. it should take you about 1 day to get back on line with pc up and running. hope this helps
SOURCE: How to restore The Compaq Presario SR1720NX to factory defaults
When you start the computer it will breifly display a button to press to enter recovery console, usualy F11 or F12 press that button and you should be able to restore it.
SOURCE: how do i restore my compaq presario laptop to factory settings
If u Create a restoring poit & use a original copy operating System then u restore it nahi to operating system repair kar le.
if u want to restore ur BIOS then open ur Bios from F2 & Load its default settings by its given instruction.............
SOURCE: Compaq Presario 1303WM.. when i turn it on, it
TO START THE PC HIT F-1
AND NEED A KEYBORD,MUST.TRY TO COLLECTED FROM ANY WHERE.BECAUSE THERE IS NO WAY .
