Car Audio & Video Logo
SARAH TRAYNOR Posted on Nov 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Siemens vdo cdr500 need code pleaseGM 13 107 918 >PA6-GF15< VDO
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1821
Points
0
Did you manage to find the code pls. I have the same PA6 GF15
GM 13 107 918 unit.
Thanks
Dpak
Anonymous
Level 2:
Sergeant:
  • Expert 344 Answers
  • Posted on Nov 28, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
344
Questions
0
Helped
70500
Points
914
Call customer service, DA
5 Related Answers
Anonymous
  • Posted on Nov 27, 2009
SOURCE: code siemens vdo cdr2005 sn:13 122 932
i have lost my code due to battery going flat siemens vdo cdr 2005
xxxxxx xxx
  • 5117 Answers
  • Posted on May 22, 2010
SOURCE: how to enter radio code for siemens vdo c500
It is showing SAFE because wrong codes have been entered.
To restore, leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two.)
Code Entry Instructions
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
xxxxxx xxx
  • 5117 Answers
  • Posted on Jun 04, 2010
SOURCE: lost radio code on vauxhall vectra VDO CDR500 radio``
Unfortunately CDR500 codes (made by VDO or DELCO) are only available from the Main Dealer or by using a Radio Decoding Service
Testimonial: "thanks v much for help.contact dealer at some point next week.cheers"
Anonymous
  • Posted on Aug 17, 2011
SOURCE: Siemens VDO CD 5404 MP3 Player
Amigo, estou com o mesmo problema, estou sem o code do radio, a senha de segurança dele é w308, existe uma calcuadora para code, mas é da renault e esse que tenho é fiat, o resultado da cal... foi 3671, tentei e não deu certo, se alguém souber um programa para saber code desse aparelho que é da fiat e tem o serial 900616505600 eu agradeço desde já, obrigado....
Anonymous
  • 689 Answers
  • Posted on Nov 06, 2012
SOURCE: CODE FOR SIEMENS VDO CDR500
You will have to contact the person that you got the car from, If it is a after market system in it, To get the code from them, If they rember the code they made up for it, Any after market system, The owner can (Pick) His own personal code for it, If it is a factory system,You can get the code from the dealer, It is done that way,Because if it is stollen,That if some one try to install it,There is no possible way to get it to work with out known the code the person put into it,
17helpful
3answers
Need code for siemens vdo 330886636 no 24 469 302 type cdr 500(e)
I NEED RADIO CODE FOR SIEMENS VDO 330886636. No.13 138 246. GM020521690276.PLEASE HELP ME.THANKS!
22helpful
4answers
Lost radio code on vauxhall vectra VDO CDR500 radio``
hello i have locked radio and need code u can help me ?
VDO 326559176
No. 24469302
Type: CDR 500 (E)
2F4
1helpful
I need a code for my siemens vdo stereo type cdr 500 serial no; gm050032037535
Unfortunately SIEMENS/VDO codes for the CDR500 are only available from your Main Vauxhall Dealer or a Radio Decoding Service
Never had the radio pass, trying to unlock radio on corsa 2003 model. the code on the front of the radio is CDR 2005 - VDO cheers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unfortunately the majority of SIEMENS/VDO codes (including your CDR500) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
My siemens VDO, cdr 500 car stereo has been locked due to my car battery going do you now the code
These CDR500 codes are only available from the Main Dealer or Radio Decoding Service
Not available for free from anywhere on the Internet
Sorry
1helpful
Do you knw what make of radio goes into my mk4 04 astra elegence cdr500. siemens or delco?
DELCO is the old name (and version) of the SIEMENS/VDO so the model number CDR500 is the same.
They should be interchangeable
2helpful
Code CDR500 GM0500V9122242
The CDR500 is made by SIEMENS/VDO (DELCO) and unfortunately the code will not be available for free from anywhere on the Internet as access is required to the original factory database which is not commercially available.
Try your Main Dealer ..........or a Decoding Service who will plug in a laptop to read/recode the memory chip (EEPROM)
1helpful
Hey i got a VDO CDR 500(E) in my astra is there any chance i can get a code for free GM050031914371 many thanks john.
Unfortunately the majority of SIEMENS/VDO codes (including your CDR500 ) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
6helpful
Code siemens vdo cdr2005 sn:13 122 932
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
