Question about Zenith ZN110 Remote Control
I have a dynex remote control that I need to use on a zenith TV. Can you give me the codes?
I have a zenith tv but a dynex remote control and I need the codes for the remote to make it work with the zenith TV please.
Posted by nationst on
    Top Expert:
  • Zenith Master
  • 76,584 Answers
Codes to check with Zenith TVs are: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Posted on Nov 22, 2012
5 Related Answers
Anonymous
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Posted on May 22, 2008
Anonymous
SOURCE: Zenith ZN-501S remote control codes and instructions
http://www.thompsontv.com/zcodes.html
Posted on Feb 20, 2008
Anonymous
SOURCE: Sony Trinitron
the code for the sony trinitron is 0414
have a nice day
Angelus
Posted on Aug 03, 2008
Anonymous
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
Anonymous
  • 57 Answers
SOURCE: zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
Posted on May 16, 2009
Code for Dynex TV
Codes for Dynex TV with RCA remote control are:
11463, 11785, 11810, 12049, 12184
Jun 25, 2012 | RCA Universal Remote Control
I need Dynex tv codes for universal remote programming
Hello
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
Mar 22, 2012 | Jensen JR300 Remote Control
Need all in one remote urc3021 code for dynex tv
Do you mean a One For All URC-3021 remote? The manual and code lists are available here: http://www.oneforall.com/support/manual . Enter Universal Remote and then the model in the drop down menus. The direct link for the URC-3021 manual is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
The Dynex TVs are usually made by LG/Zenith. You can try the Zenith codes: 0017, 0463, 0178, 0092 .
However, universal remotes are usually limited to having only codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
(the URC-3021 remote manual has a 2004 copyright date.)
Jun 28, 2011 | One For All URC-3021 Remote Control
Remote control code for camcast
These brands:
DYNEX, ORION, EMERSON, INSIGNIA, MEMOREX, SANSUI, SYLVANIA, and ZENITH
may use the same codes so look for those brands above in the Comcast remote codes listing.
Jun 10, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Zenith ZN110 Remote Control Logo
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
