Baby Gear Logo
Question about Baby Gear
Hair stuck baby walker
The wheels have hair stuck in them and we don't know how to get the wheels apart to clean them out. The back wheel won't even turn anymore! This is an old style baby walker where all four wheels pivot 360 degrees.
Jocelyn B
Hi ,
I’ve spent days trying to clean out our baby walker wheels. There was so much hair inside wrapped so tightly that it was impossible to remove. After researching and not getting so much information but the usual steps that did not work for me. I thought, what’s good to dissolve hair. DRANO!! So I figure why not try.
I soaked the wheel in drano overnight, the following morning, the wheel was much looser but still had a lot of hair inside. Repeated the same step overnight and left the wheel in hot water afterwards for a few hours. After grab the wheel, and keep spinning it and twisting in different rotation. Hair will begin to fall out and wheel becomes much looser. Keep spinning as much as possible throughout the day. And finally the wheel is fixed!! ?? .. if hair is still trapped inside, just keep leaving it in drano and hot water, repeat as needed!! Hope this helps!!
Posted on Feb 22, 2020
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: 1999 jeep grand cherokee all time four wheel drive will not engage
Sounds like the splines on your transfer case gear are ground down
Posted on Apr 23, 2009
Stiff wheel
Hi Kristia
We would recommend you contact Bugaboo for assistance.
Bugaboo UK
How to replace seat in jetta beepa walker
Contact Jett's beeper manufacturers customer enquiries, they should be able to tell you who your local spare parts distributors are. I have changed similar material seats before and they usually just clip into place on the underside of the frame.Its a simple job
Aug 07, 2013 • Baby Gear
Do baby walkers teach babies to walk?
If only it were that easy :) I don't suggest you let your baby use a walked until he or she is very strong on their feet. Since walkers are on wheels, it's really easy for babies to fall and hurt themselves as the wheels more the walker too fast.
Jan 30, 2013 • Baby Gear
Front Wheels jammed up. Replace or cleaning tips?
I have the same issue did you ever get that fixed? I was able to clean the back ones with out a problem.
1helpful
Hi, we have a bugaboo cameleon and now the front wheels is not working smoothly and I can see a lot of hair stucked on it, may I know how to how to remove the hair stuck on the front wheel
The wheels are held in by 8 mm domed star lock washers they are supposed to be used only one time. You can pry them off with a couple screwdrivers then the axel can be taped out using a large nail as a punch. If this sounds all to hard just pop down to your local bike shop. They should be able to pop it out, clean and lubricate the axel and reassemble in a quarter hour.
How to clean hairs and stuff from the front wheel of a Bugaboo Cameleon? I'm trying to remove the wheel itself from the assembly; but afraid of damaging -- I don't see any obvious way to take it...
The wheels are held in place by www.starlock.nl/Products/Dome_capped.php you can pry them off with a couple of screwdrivers. It is best practice to replace them but you can usually panel beat the prongs back into a usable condition. I sell them 4 for $10 but shipping from New Zealand is twice that again so best to find locally.
If you find this helpful please rate it!
2helpful
2answers
Roomba only goes backwards for a brief time then shuts off and beeps nine times. I've taken it apart and used can air to clean the 4 sensors. Any other suggestions?
Have you popped out the black and white castor wheel and cleaned that out? It is a part that should be replaced from time to time. The vac uses an optical sensor to see if the wheel is moving. If it isn't, it tries to back up and see if something is stuck in the wheel. Pop the wheel out, clean it and the shaft it sits on and put it back in. Wipe out the cavity before you reinstall it.
Mar 11, 2011 • Vacuums
Stuck front wheel
I have the same problem, but it looks like no one has the solution. I have taken the screws out of the wheel but that doesn't help remove the wheel to check what is stuck. Help us!
Top Baby Gear Experts
Marvin
Marvin
john h
ADMIN Andrew
ADMIN Andrew
Are you a Baby Gear Expert? Answer questions, earn points and help others
