Need to know how to mount the alternator
1. Remove serpentine belt
2. loosen power steering pressure and return hoses
3. Remove nut from pressure line mounting on alternator bracket
4. remove power steering pump mounting bolts.
5. Lift pump assembly from engine mounting and remove hoses.
6. Reverse order to install. Fill and bleed system.
NOTE: A new or rebuilt power steering pump will most likely not come with a pulley attached. You will need a power steering pulley remover/installer tool to transfer the pully from the old pump to the new one.
For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
Click to Enlarge
... then swing it out of the way for access to the alternator assembly
Click to Enlarge
View of the alternator electrical
connections-(A) battery positive, (B) field terminals, (C) wire harness
hold down, (D) ground terminal
It may be necessary to remove the alternator and mounting bracket from the vehicle as an assembly.
Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Click to Enlarge
Remove the front alternator assembly mounting plate from below the vehicle
Click to Enlarge
After removing the alternator assembly front mounting plate, remove the front engine-to-alternator bracket mounting stud
Click to Enlarge
Remove the two alternator bracket-to-engine mounting bolts Remove the alternator and mounting bracket assembly from the vehicle
Click to Enlarge
If re-installing, the alternator has a pivot bushing on the pivot arm that should be pushed out before installation
Mount a C-clamp and 18mm socket on the alternator pivot bushing ...
... then compress the C-clamp until it pushes the alternator pivot bushing out
To install:
Fig. 1: For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
Fig. 2: ... then swing it out of the way for access to the alternator assembly
Fig. 3: View of the alternator electrical connections-(A)
battery positive, (B) field terminals, (C) wire harness hold down, (D)
ground terminal
Fig. 4: Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Fig. 5: Remove the front alternator assembly mounting plate from below the vehicle
Fig. 6: After removing the alternator assembly front mounting
Fig. 7: Remove the two alternator bracket-to-engine mounting bolts
Fig. 8: Remove the alternator and mounting bracket assembly from the vehicle
To install:
