Question about Beurer Pm 90 Heart Rate Monitor - Silver/Grey
I've bought a beurer pm 90. Trying to pair the monitor to the chest strap but it's not working. Any hints plz
Ive tried to pair them. It gives me no device found. The chest strap was mounted on ,y chest and also made the contact wet too. Any ideas on why it is not pairing?
Posted by Salem Salem on
David Foster
    New Friend:
HI
I realise it's been a long time since you posted this question, but having just bought one of these myself I'm having the same problem.
I wondered if you managed to resolve the issue and if so, how?
Thanks
Dave
Posted on May 11, 2013
Sportline cardio 660
Try to humidify contact area on chest strap(each side front). Also batterie weak in strap?
May 11, 2013 | Exercise & Fitness
Tip
Tips For Your Heart Rate Monitor
First, you want to adjust the fit of the chest strap. <br /> <br /> Moistening give a more comfortable fit by reducing friction and will also help create a better connection between your skin and the receiver. It can also increase the lifespan of your belt.<br /> <br /> When properly looked after, your heart rate monitor watch should far outlive the chest strap. More often than not any problems you find with the watch can be traced to the chest strap or the batteryIn terms of conservation, the most important thing you can do is ensure that your watch is no longer monitoring after you return from your run. <br /> <br /> This should be easily achievable through the interface on the watch. Separating the watch from the monitor component by a significant distance will ensure that no unwanted connections continue after use.<br /> <br /> Where possible, make sure to remove the electrical component before rinsing the strap with some running tap water. If the watch and electrical component are particularly dirty, you can use a damp cloth to wipe them down, before putting everything aside to dry. Be sure not to leave the chest strap in the sun as this can cause the material to deform, making it itchy and uncomfortable to wear.
on Jan 08, 2011 | Exercise & Fitness
Garmin Edge 705 Heart Rate Monitor Not Working
It could be that there is a failure in the circuit between the two pads on the chest strap and the HRM electronics in the middle. If it won't work at all try putting the battery in backwards for a few seconds (this is supposed to accomplish a reset) and then try re-pairing it with the Garmin. If this doesn't work, I suggest a new HRM. I've hadevery good luck with my Wahoo TICKR and a Garmin 502.
Mar 24, 2017 | Garmin Cycling
I have a Duo 1025 for women. The watch doesn't seem to detect the chest strap transmitter. It was working alright when I bought it and tried using it a few times. But now the watch is not giving a...
Make sure the battery is placed underneath the small copper clip (positive lead) inside, else the circuit isn't complete. It's pretty easy to clothes the battery casing with it above the lead and not even notice it.
Jul 26, 2011 | Sportline 1025 Duo Heart Rate Monitor...
Sometimes, my watch gives me crazy readings such as 221 bpm at rest for my heart beat when I use the chest strap transmitter. What causes that and how can I prevent it? Could it be my WiFi internet network...
Make sure your chest strap is a good fit so it doesn't move, not too slack. Also you need to wet the sensors so that you get a good connection. On the Garmin ones they recommend using an electrode gel but that costs money and I find spit/saliva works just as well.
Jul 25, 2011 | Sport & Outdoor - Others
I bought an ft4 monitor in nov 2010 and when I am exersizing for approximately 20 minutes the monitor loses signal from the transmitter. I can sometimes get a signal back by pressing the transmitter strap...
Look in my tips and tricks page for the most common issues regarding Heart Rate transmission, if none of these fix it, then you "may" have an issue with the equipment itself. Generally the most common issues area:
Strap not on correctly (too loose, too low, upside down, not enough wetness to conduct)
Environmental factors (signal interference, etc)
Mar 25, 2011 | Polar Heart Rate Monitors
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Jan 02, 2007 | Timex Ironman Triathlon Heart Rate Monitor
Beurer Pm 90 Heart Rate Monitor - Silver/Grey Logo
249 people viewed this question
Top Beurer Exercise & Fitness Experts
Tom Chichester
ray gallant
Info Hub
Info Hub
Are you a Beurer Exercise and Fitnes Expert? Answer questions, earn points and help others
