I have a Sony Handycam Vision CCD-TRV69E. I was using to view tapes. After viewing 6 or 7, I put a tape in and didn't see anything on the screen (screen is blus) or through the view finder. I know it is working because I can see the mechanism turning and the counter is working, too. What to do?
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
SOURCE: Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
Thanks for using fixya.
SOURCE: lcd screen is blurry on my sony handycam dcr-hc20
This does not sound like a CCD problem yet, but a LCD problem. This would require you to replace the LCD screen. Sounds like the LCD inverter is shot. That is the power supply that is required to back light your LCD.
Before we blame that, you should make sure that all ribbon cables are secure and tight.
Good luck !
SOURCE: handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
SOURCE: Sony Handycam Vision ccd-trv308
I have the DCR-HC32. I got the c:31:22 error with a message to reload the tape. I could load another tape and saw a post that if a tape is at the end and the tension is tight the camera has a sensor that won't load the tape so that it does not break it. I loosened the tape after a few tries and it loaded fine...no more errors.
