Question about KLH CDR2000 2-Disc CD Recorder
MKLH CDR 2000 readsbackwardsc T Backwards C iodC-191....Error...I can't use it PLEASE HELP
Reads disk or software error please powercycle and retry...Nothing works
Posted by Robert Epps on
2 Related Answers
Anonymous
  • 112 Answers
SOURCE: Cdr side reads software problem
Common issue with this machine. Do you have the update disc? It is available online IIRC but I do not know where. Google is your friend :-)
Posted on Feb 20, 2008
Michael Borelli
  • 979 Answers
SOURCE: disk or software error
You may be copying discs that have Digital Rights Management, or DRM encoded on the disc. You should have "burn rights" before trying to run copyrighted material...accordianman
Posted on Jun 15, 2008
Marantz cdr510 reads cdr error
Please give more details.
6helpful
1helpful
I can't install adobe flash player the error reads adobe.com/go/tn_19166...please help
Follow this link to trouble shoot this error:
http://kb2.adobe.com/cps/191/tn_19166.html
DVD CD-R drive does not recognize a blank CD on toshiba sattelite
Try this before you enter disk.
  1. setup software or files to transfer when prompted to enter CDR, then place in drive.
  2. Or open my computer, select cd drive right click select, format disk. When prompt comes up for disk insert CDR.
Some systems have trouble with other manufactured formatted disk.
Unexpected error
Hello Josh,
Vista Business, great. So you are coming up with an error. I suspect this could be an issue with the disk being dirty or scratched or the CD drive is messed up. Let me give you a link to the software and you can download it and install it that way.http://www.microsoft.com/hardware/download/download.aspx?category=ICE. Let me know if this solves the issue.
Thanks,
Armymason
2answers
CD RESET FAILURE
The CD ERROR 277..can be fixed if u make sure the internal cable connection between the Hard disk and the writer are not mixed up and are well fitted...
1helpful
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
I am trying to install the Camedia Master software into a new pc, but when the disk gets to 90% loaded it freezes.
A CRC error (Cyclic Redundancy Check) is a data corruption error. This basically means that the data read from the media did not match what was expected to be read by the software. I would say that it is most likely that the source media that you are copying/reading from is corrupted. It is also possible that the destination media that you are copying to could be the source of the problem. If it is a hard drive try running scan disk or other disk repair software, if it is a CD - clean or replace the CD. David Millier Advance Camera Repair
Error message and texture problems
I found I needed to change the user to a Power User and it solved the initial error problem.
KLH CDR2000 2-Disc CD Recorder Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
