Question about Microsoft Windows XP Home Edition English for PC
Dynamode 6- channel pci Sound Card installed but no sound. Says Drivers not installed
Fitted Sound Card but cant get enclosed Cd To install Drivers
5 Related Answers
jeet_helps
SOURCE: in place of vista i installed xp(sp2),after that sound problem.
first install RealTek high definition audio driver R1.80
Then restart computer
Get sp34200.Just google you will get it easily.Insatall it.It will stop in between giving message "could not find media
for this device" but don't worry the required files have been copied.
Now goto Device Manager> OtherDevices > HD Audio
Now rightclick it and select Update Driver
Select "no not at this time" when prompted to connect to internet
Click on next
Select Install from a list or specific location
Cick next
Select Don't search i will choose driver to install
click Next
show all devices
click Next
Click on "Have disk"
Select c:/swsetup/sp34200
Select the .inf file
Click ok
Restart.You are done.
Posted on Feb 20, 2008
Problem Solver
  • 102 Answers
SOURCE: Realtek HDA driver
The driver you are installing needs more requirements. try to install driver from mother board CD. If not try to download realtek HD driver compatible to your processor.
Posted on Aug 29, 2008
Anonymous
  • 336 Answers
SOURCE: sound card
I need to know the sound card make and model, and I also need the computer manufacturer, if you can not get the sound card information.
RCF
Posted on Aug 31, 2008
Anonymous
SOURCE: PROBLEM IN SOUND
if u hane vista 32 bit then just uninstall the driver from device mansger and then add driverfrom cd !!!!!
Posted on Oct 24, 2008
fordey08
Graham Forde
  • 155 Answers
SOURCE: i wan't to install vga & sound driver
Download " Driver Magician ". There is a small fee for registering the product but once done, it searches for and updates all drivers on your system.
Posted on May 04, 2009
Respected Sir, I bought a brand new PCI Sound Card 6 channel from zebronics & when I Install it to my PC & connect it to my Home Theatre System It only produces 2.1 Channel sound. Try to help me to...
Check your sound card if is it connected properly or not. This problem also because of improper drivers or absence of drivers. Check your wiring connection also.
Jul 25, 2010 | Computers & Internet
I have installed os xp in my pc but i cant able to get the sound output in my speakers
its just because the sound card drivers are missing u can install them from the CD u got with your PC! if u are using the on board audio card then these drivers will be on the motherboard CD! if using pci card then it will be on the CD/floppy u got with it! or else search the net for drivers.
if needed anymore support regarding this then do reply and rate!!
Jul 03, 2010 | Computers & Internet
Hello i like to install speaker sound drivers ...
Speakers do not need any drivers!! Your sound card need drivers.
If your sound card is PCI, remove it and reinsert it to the PCI slot again and see whether your system detect the device and use the sound CD to install the drivers. (Change PCI slots if necessary and turn off the PC before changes the PCI sound card).
If your audio device is intergrated device, check the Bios to make sure the sound/audio is enable.
Note: Check the device manager first to see any audio device had been install properly.
May 20, 2010 | Computers & Internet
Realtek AC'97 won't produce sound in Win XP and neither will the new CMI sound card I installed. When investigating the drivers I a rundll32 error after closing out of the options for setting default wav,...
remove all the drivers installed and re install the latest drivers again ...if you still face installation issue try re installing the ms installer new version. and try again...
Mar 05, 2010 | Intel CMI 8738 6-Channel 5.1 Surround...
My sound card doesn't work
load the motherboard cd and try to re install all the necessary modules for the drivers. if that does not work, get youself Foxcom cd, it is suitable with most motherboards to help you load the sounc card drivers.
thank you
wonder
Sep 17, 2009 | OEM Systems OEM: 32-bit PCI CMI8738-6 5.1...
NO INSTALLATION
Hi Adnan,
Here's an easy way to download and install / update your sound drivers, especially if you don't have the driver CD or can't install from the CD, for any reason.
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve the drivers for you.
You can download this free driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.cfm (copy/paste the link if you can't click it)
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers. Try it out. It works.
For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
Hope that helps,
Regards,
Raspal
Oct 17, 2008 | Intel CMI 8738 6-Channel 5.1 Surround...
My audio card
Hey its is problem with drivers
Please follow the steps to resolve :-
1)Download the UAA drivers first from microsofts site
2) Download the Latest drivers from
http://www.realtek.com.tw/
PCI drivers + Latest Audio drivers
3) windows installed 3.0 / 3.1
4) now go into Add / Remove programs and uninstall the previous version on Realtek drivers also remove windows installer if available
5) now restart your systems
6) Now installe the windows installer first -> restart
7) now install the UAA drivers -> Restart
8) now install the Realteks latest version -> restart
If it does not solve your problems please do reply i have other trick too..::.. :-)
May 30, 2008 | Computers & Internet
Sound card
jonny,
  • just place it in your motherboard's PCI slot.
  • boot your system and install driver for it.
  • After successfull installation of driver you will be able to use your sound card.
Thanks
Iqbal
May 18, 2008 | Computers & Internet
Foxconn sound card drivers
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
Apr 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Microsoft Windows XP Home Edition English for PC Logo
206 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
