The touchpad cursor on my laptop suddenly freezes while working. and the system had to be forced shut down to get it work, but it works fine with the mouse. How can this cursor on the touchpad made to work properly without shutting down the computer.
SOURCE: Laptop's touchpad not working
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
SOURCE: close lid of laptop without shutting down system
You have to configure what laptop do when the lod is closed . go to Control Panel , Power Options , Advanced . In this tab you will see an option " When I close the lid " and a drop down menu just choose do nothing and press ok . It will not shut down your laptop when lid is closed .
If you like my solution do vote for me
Farhan
www.senseapplied.com
SOURCE: Acer Aspire 1640 laptop mouse pad does not work
Hit the Fn (funtion key) HOLD it down WHILE pushing the F7 Key - this will turn your touchpad back on.
For the complete manual for your computer:
http://www.acerpanam.com/synapse/data/7117/documents/AS1640_Guide_EN.pdf
And these instructions were found on page 25.
SOURCE: Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
SOURCE: synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
