Your new bulb may be bad use bulb replacements,com I got a bulb from hem fo r my60" toshiba $125 ups inc. and only had to tke out 6 screws but now im getting white dots
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
It's likely the lamp ballast has failed. The ballast powers on the lamp. You can also reseat the lamp & make sure the lamp cover is replaced evenly or the safety shutoff switch under the lamp door may not be depressing which will cause a no start.
ok then, it sounds like it is trying to strike the lamp on some of these Sony projections it will keep trying to strike the lamp even though the bulb is no good. The lamp error detection may not be working correctly, there is a detector loop around the ballast and if it is not positioned correctly it cannot correctly detect a bad lamp. Try removing the lamp and see if it is physically damaged, if not it still may be bad and is the most common cause for a no error condition and no light problem.
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
According to the manual, yes . . .probably gone past the recommended hours of lamp use. Press the OFF or the HELP button on the remote for 10 sec, this will reset the lamp hours value and allow the unit to come on. If it don't, NEC will tell you that it has to be sent to a repair center.
