I have checked USB Ports in Device manager, reinstalled them, originally thought it was a mouse problem so checked that and found out no USB ports were working, uninstalled in device manager, restarted machine, didn't help, went to HP and they didn't have drivers just for the USB, flashed the Bios, checked BIOS for settings for USB, none. Now I'm at a loss. OS is Vista home Premium -32 bit. AMD Turion64
SOURCE: drivers for xp pro presario c508us downgdare
I also upgraded a new Compaq C751NR from Vista to XP, and the last yellow tag in device manager was-acpiHPQ0006
I used the driver from ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38171.exe
and used the 'setup.exe' in the folder. Worked perfectly.
SOURCE: USB not working on HP NX7010
I have the same problem. No sctive USB ports, yet device manager shows ok. updated system BIOS and Intel chipset from HP site - still no good. Also removed bluetooth unit, still no good.
Turned off USB power management, still no good!
The laptop was working perfectly until this happened.
Any more suggestions?
SOURCE: hp pavillion usb ports
They are right, some DVs have this problem. If you can live without the ports, then do it. If you can't, replacement is the only option.
SOURCE: need audio device drivers for compaq presario amd
donwload here.. or update you server 2008 sometime driver for the vista or xp x68 is not supported of 2008 server. try update..server
http://welcome.hp.com/country/us/en/support.html
