Computers & Internet Logo
Posted on Nov 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hiya,its an acer aspire 4810t laptop.the f3 button has a bluetooth icon on it,but still unsure how to turn on.thanks
Still trying to enable bluetooth function on this machine...
Anonymous
Level 2:
New Friend:
  • Expert 119 Answers
  • Posted on Nov 20, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
119
Questions
0
Helped
16477
Points
312
You are looking for one of my favorite keys...the "fn" (or function) key. Juust left of the windows key (under your left palm) is the fn key. Pressing this key at the same time as a key with the F3 key will toggle your bluetooth on and off. In fact, the fn key will toggle several keys if they have a blue icon printed under the main number.
5 Related Answers
Anonymous
  • Posted on Dec 26, 2007
SOURCE: Acer Aspire 5310 Bluetooth Heeelppppp
I Also have the Aspire 5310 and when you press the bluetooth launch button it says 'No Bluetooth Device', this is becasuse it does not have the Bluetooth card installed into this computer and this is an extra for your laptop... hope this helped.
Thanks
Anonymous
  • 679 Answers
  • Posted on Dec 18, 2008
SOURCE: bluetooth location on acer laptop
Bluetooth other than the device itself is software, the "bluetooth dongle" gets plugged into a port via the usb, So I am thinking you need to plug it in to the computer. If it is a new machine if may be internal, that would be under programs, start programs, if no bluetooth it must be installed the software and hardware, good luck
Anonymous
  • 505 Answers
  • Posted on Jan 02, 2009
SOURCE: acer aspire 5500z driver bluetooth
First of all check if your Laptop has the bluetooth feature. If it has then the driver should have been automatically installed. There is a button in your laptop, make sure that the bluetooth is on.
Thanks
Anonymous
  • 8 Answers
  • Posted on Dec 30, 2009
SOURCE: How do I enable my bluetooth on my Acer Aspire
Make sure you have the driver for the bluetooth installed http://support.acer.com/us/en/drivers_download.aspx
here is a link to the driver downlod page. You can check it by going into System Properties then click on Hardware tab to see if it is installed properly. (right click on My Computer Icon and select Properties to get to the System Properties)
FordFan101
  • 45 Answers
  • Posted on Feb 14, 2010
SOURCE: my acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
1helpful
How to use the bluetooth
press Fn + F3 and it will pop up a box that you can switch either your WLAN or Bluetooth
if the switch doesnt come up check the BIOS setting to see if the Bluetooth was disabled from there
How do I activate Bluetooth on Acer Aspire 4810TZ-4696?
Check to see if there is an "Fn" key to enable Bluetooth. Most Acer's have a bluetooth icon on the F3 key. By pressing Fn-F3 you are able to enable or disable bluetooth.
Is there an external switch to activate Bluetooth?
Check to see if there is a "Fn" key to enable Bluetooth. Most laptop's have a bluetooth icon on one of the "F" keys. e.g By pressing "Fn-F3" on an Acer or "Fn-F2" on Dell or ASUS, you are able to enable or disable bluetooth.
I click 'turn adapter off' on bluetooth icon in task bar and now i cant transfer using bluetooth anymore. when i try to send file using bluetooth, message appear like this "bluetooth device not found....
you was torn off your bluetooth, go to control panel> bluetooth device and you can enabled your bluetooth device tthere
or use shortcut key Fn+F3 to turn on or turn off your bluetooth device
i hope this helpful
thank you for using fixya
How do i turn on the bletooth
If you press the fn key and the wireless key (F3), you should have the option to turn on the wireless and bluetooth.
The following are instructions for windows 7.
To install a Bluetooth enabled device
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
  2. Click Add, and then follow the instructions.
The bluetooth logo is there but each time i try to enable it,it keep telling me that there is no device and i was told in the customer,s guide note to enable it by clicking Fn + F3 but each time i try...
Sometimes on laptops there is a access panel on the bottom of the laptop that when you take them off will show slots for inserting additional ram, wireless network, modem and bluetooth modules. If you can look and see you may find that your laptop has the capability for bluetooth, but may need a card installed. If your laptop does not then you could always buy a usb bluetooth like the one here: http://www.cellularfactory.com/laptop/ACER/4/31883/518537/
Thanks, Matt
How do I enable the bluetooth settings on a acer aspire 7736z?
Hi there,According to the Acer Manual for your Laptop,The Fn+F3 keys Enable/Disable bluetooth.You can find out more about your laptops capabilities here...
http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/QS_ACER_7736_7736Z_1_0_EN.pdf
Hope this helps,Good-Luck.
4helpful
2answers
Acer 4810t. how do I turn on the bluetooth
Check your Device Manager to make sure you computer has Bluetooth capability. If there is no Bluetooth in your control panel, you may have to install the drivers and use the software. You can download the drivers and software from here for the 4810T:
http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_6.2.1.800_Vistax64Vistax86W7x86W7x64_A.zip?acerid=634024298954715268&Step1=Notebook&Step2=Aspire&Step3=Aspire%204810T&OS=V10&LC=en&BC=Acer&SC=PA_7
2helpful
How do u turn on the wireless capability on an acer aspire 4810TZ?
The "Communication Key" controls the wireless function. This key is located above the keyboard on the right. There are a series of keys together to the left of the right speaker port. The communication key is the far left key in this group of buttons.
If you are trying to enable bluetooth simply press the fn+F3 key to turn bluetooth on.
7helpful
6answers
Thanks
Grand Canyon Tech
Grand Canyon Tech
