Kodak EasyShare Z740 Digital Camera Logo
Posted on Nov 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pictures are to dark
When i stade back about 50 to 100 feet my pictures come`s out to dark is their anything tha i can do to prevent my pictures from coming out to dark?
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Nov 20, 2012
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86401
Points
1069
If you are doing flash photography you will have to limit the shots to a distance of 10-15 feet to get nicely lit pics. also try setting the exposure compensation to +2 to brighten up the pic. Also are you shooting on manual ???
5helpful
The problem is that u know the sony hdv xr500x when u put it on the picture is very dark we have tried it under light too put but the picture is still dark
Hello
When you look at your pictures are they dark, murky and hard to see? If you took pictures at a wedding, dance recital, theater performance or any indoor event and they came out dark, read on to learn why your pictures are dark, and how to fix this common camera problem.
Many people take pictures of indoor events, only to be unsatisfied with the final outcome of their photos. Although you may have bought the top of the line film or digital camera, there are a few limitations that you need to know about.
To correctly expose your pictures, you camera needs a lot of light. The compact point and shoot varieties adjust for this when you're outside during the daytime, and usually your pictures turn out fine, right? Well, then how come when you take indoor pictures, they sometimes come out too dark? There are two culprits; your zoom function and your flash.
Most compact cameras today offer a zoom function. When I used to work in retail photography sales, the first feature that consumers would ask for is zoom. People love to get close-up pictures without using their feet. Although zoom does bring your subject matter in closer, it also decreases the amount of light that can get into your camera. Essentially, the more you zoom, the less light your camera can receive, and your pictures will be darker.
So, if your taking pictures indoors, in a dark church, gym or other window-less room it is very difficult for your camera to get enough light to properly expose your pictures.
This is when most photographers decide to turn on their flash. The flash on your camera is a great tool to illuminate dark situations that are in close proximity to the camera. Most built-in flash units are designed to allow the light to travel 8-10 feet away in poor quality light and up to 15-20 feet in brighter situations.
What most camera users fail to realize is that although your zoom function is visually bringing you closer to the action, you flash cannot reach that far to illuminate the subject, and your pictures will be dark.
Hope it helps, if so do rate the solution
Problem with the camera in dark placesflash
Did the flash go off? Is the subject farther than 10 feet because any more than that and your flash will not illuminate it.
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
- Flash goes off but pictures dark (very)
You don't say what kind of pictures you're trying to take but, understand that the built-in flash is only effective for about 8 - 10 feet.
Oct 14, 2009 • Cameras
1helpful
PROBLEM WITH PHOTO IT IS DARK WHEN USING FLASH
Digital cameras step down the aperature when you have the flash on in anticipation of the flash brightening the surroundings. WHat they don't advertise is that the built in flashes with the new compact digitals are only effective out to about 6 feet. If you are taking pictures at concerts or sunsets do not use the flash. If you are taking pictures of people close up make sure that you have set your scene/mode dial or menu to the appropriate setting. If you provide tha make and model of your digital ca,era I can likely link you to a copy of your owners manual. You can also increase your ISO setting (higher number) to increase the sensitivity of your camera in low light settings.
May 31, 2009 • Cameras
2answers
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
