wont reset until repair have problem with throttle body position sensor /circuit repair problem https://repairpal.com/obd-ii-code-p0121 https://www.yourmechanic.com/article/p0121-obd-ii-trouble-code-tps-a-circuit-range-performance-problem-by-jay-safford
Definition of Diagnostic Trouble Code P0106
Category:
Powertrain
Definition:
Manifold Absolute Pressure/Barometric Pressure Circuit Range/PerformanceNote: This definition of P0106 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0121
Category:
Powertrain
Definition:
Throttle/Pedal Position Sensor/Switch "A" Circuit Range/PerformanceNote: This definition of P0121 is applied to all manufacturers
code p0121 refers to throttle position sensor(TP) A/ accelerator pedal position (APP) sensor A --range performance problem===causes---accelerator cable adjustment---TP/APP sensor ---wiring
check that the cable is not broken and/ or replace the sensor.
P0121 Is a throttle/pedal position sensor/switch "A" circuit range/performance problem. P2544 torque management request input signal "A". U0101 lost communication with transmission control module. I hope these definitions help.
