You will find a complete list of error codes at https://www.sony.com.au/electronics/support/articles/00008857
The compact camera displays error code beginning with or System error Sony...
Hi there:
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
• Turn the camera off
• Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
• Turn the camera on
• Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
• Lift the camera away from the hard surface and notice that the error message is gone.
• Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
