SOURCE: washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
SOURCE: my washing mechine washes with only cold water
Most modern washing machines take water from the cold supply only. They heat the water inside the machine.
If a machine is washing in cold water (i.e. not heating the water), then it has a fault and an engineer needs to be called.
If, on the other hand, the water is being heated and the clothes aren't coming out clean enough, the problem could be that the quantity of laundry exceeds the quantity recommended for the programme used. You can usually put the maximum laundry weight in for a hot cotton wash, but you have to restrict the quantity to about a third of the4 maximum weight for a wool wash.
If the machine is stuffed full and being run on a 40 degree easy care wash, the clothes won't come out as clean. In this case, the solution is to reduce the amount of laundry in the machine.
