"Replacing fog light bulbs on 2013 Santa Fe". Raise vehicle if you are a big person. In front of front wheels triangular plastic panels exists. Remove Phillips head plastic screws in chosen panel (2ea). Pull panel down. Stick hand through opening, remove wiring connector from bulb. (Bulb will not come out unless you do). Twist bulb housing counterclockwise and remove. Install new bulb, reverse procedure and don't touch the glass part of the bulb.
SOURCE: What is the best way to replace a fog lamp bulb on
1. Turn tires away from car
2. There is a plastic covering in front of the wheel that usually goes
around the wheel well. There are plastic thumb pins on the outer edges
of this plastic covering. Remove the thumb pins and this plastic piece
will come off.
3. Behind this you will find access to your fog lights.
4. Then you can remove the fog light by twisting the plastic cover (if it has one) or by twisting the bulb
SOURCE: 2007 Hyundai Santa Fe - Replacing fog light
hi have not had pleasure of this on santa fe yet? but will try to help dependant of which side o/s or n/s ? i would first remove the screws holding the front of the under engine plastic cover/shield and drop down sufficient to gain view/access? to the rear of fog lamp then if a cover is on? try turning anti clock to remove? or if rubber cover pull off? then the bulb and clip should be visible? unplug the wire from bulb then the spring clip holding bulb in place normally just sring the 2x top ends together and swing down/clear to remove bulb? refit new bulb correctly! pay attention to position old bulb positioned? then clip securely and re connect wire at this stage it would be best to ensure bulb works ?? before you re assemble all else? wish you luck and hope this helps with your problem ?
SOURCE: Fog Light Replacement Hyundai Santa Fe
The above statement is GREAT!!! The wheel-well piece folds down across the area you need to be in. There are 2 screws to undo this part. Push it back and there is a cap that unscrews which holds the wires and socket he is talking about. Unscrew the cap, unscrew the wire and housing. The bulb comes out. You pull the wire harness off and install the new bulb. It has a triangular push-in and it has to go just right so take note of how it comes out. Also, being a halogen light bulb, do not touch the bulb with your hands - the oils will make it explode.
SOURCE: HOW I CAN REPLEASE 2004 SANTA FE FOG LIGHT BULB
there is a lock tab that needs to be depressed and turn counterclockwise at the same time.
SOURCE: How do I replace fog lights on my 2002 Hyundai Santa Fe?
Look up into the bumper and see if you can access the fog light. The bulb should just twist out of the back. If not, the assembly should either pop forward or back to come out. I've heard though, that many santa fe's require the removal of the entire front bumper fascia just to get to the bulbs in which case you'd have to remove your headlights to get to the screws holding the bumper fascia on
